964 Forum 1989-1994
Chronicling the restoration and rebuild of Wilbur, the Pig
Old 03-20-2018, 09:43 PM
  #31
Dingo
Dingo's Avatar
Originally Posted by sooner964
Hey Dingo,
I think this is the piece you are looking for. It is the Porsche OEM hot air elbow for the RS / Cup models in ABS plastic, p/n 993-211-941-00. Much nicer than the carbon fiber pieces. Also, there are many complaints about the fitment of the cf pieces. As Foxman said, there are a few things you have to do in terms of tricking the HVAC system to think the rear blower is still in place, but there are many examples of this on the forum. Search for something along the likes of "heater blower bypass". There are a few different ways to do it. I tried most of them and never got any of them to work, but it seems I'm in the small minority. I ultimately decided that, although I loved how much it cleaned up the engine bay having the bypass installed, I really preferred having a fully functional HVAC system. Living in Houston, you don't need heat often, but with the humidity, you definitely want to be able to defog your windows! Hope that helps a bit.
Hi there, thanks for the info.
Will do some searches when the time comes.
Yeah I love everything minimalist and tidy but I'll keep everything to reinstall if I change my mind!
Old 03-20-2018, 10:01 PM
  #32
Bloose993TT
Bloose993TT's Avatar
Subscribed.
Old 03-21-2018, 12:24 AM
  #33
Foxman
Foxman's Avatar
Sooner964 is right on with that information, thanks. As noted , the Heater Bypass Duct is Part # 993 211 941 00. And the go to thread on the wiring solution is anto1150's "Heater bypass - definitive wiring solution" thread. https://rennlist.com/forums/ But there's really nothing definitive about the solution. Some cars work with the simple Relay (Part #964 610 184 00), while others with a hard wire work-around or don't seem to work at all. MY 90 and 91's reportedly need the hard-wire solution, but only the Relay solution worked for me.
Originally Posted by Bloose993TT
Subscribed.
Thanks Bloose993TT - nice avatar!
Old 03-21-2018, 01:45 AM
  #34
Foxman
Foxman's Avatar
The Fox Family went to Florida for the Christmas Holiday. Plenty of free time to think about new projects, and Rennline was having a Holiday sale. I'm a big fan of Rennnline. Rennline has great products, and great service from a down to Earth sales staff. In anticipation of installing a light weight battery, I picked up a Rennline battery mount. The battery mount is a stout 2.25 lbs., but Wilbur will be doing auto cross and DE events eventually and velcro wasn't an option. I also purchased the Rennline lower dash delete cover, air=bag delete cover, a quick-release fire extinguisher mount, and the new tow hook with Go Pro mount. Hey, it's Christmas.
Rennline Battery Mount (photos courtesy Rennline)
Rennline Fire Extinguisher Mount
Rennline Lower Dash Delete
Rennline Airbag Block-off Plate
Rennline Folding Tow Hook with Go Pro Mount - Merry XMas!
Old 03-21-2018, 02:05 AM
  #35
Foxman
Foxman's Avatar
Installing the Rennline lower dash delete cover is a great project for the 964. It opens up additional space in the cramped cabin for leg room - great for us taller guys. It also sheds 20.5 lbs. off the car. On a scale of 1-10 for degree of difficulty, I would rate this project a 3. The initial plan was to retain the radio, but I eventually decided to jettison the radio, amplifier and speakers for an additional 9.6 lbs. of savings. Total weight savings, over 23 lbs. removed from the car.
Stereo head unit out
3 1/2 lbs. saved
Pulled the CCU
I used a small mirror to spot the two screws on the inside of the dash.
10mm extended socket
I wrapped some tape around my finger to keep the nut from falling behind the dash
Old 03-21-2018, 02:10 AM
  #36
Foxman
Foxman's Avatar
Almost there
The airbag is finally in sight
Airbag is out!
everything gets weighed
Old 03-21-2018, 02:18 AM
  #37
Foxman
Foxman's Avatar
Airbag weighs close to 6 lbs.
The Rennline supplied screw comes unpainted.
A quick shot of satin black, and it looks poroper
Lower dash delete complete!
Weighing more bits
Old 03-21-2018, 04:07 AM
  #38
Peteinjp
Peteinjp's Avatar
Gonna do center console delete on this one???
Keep it up- looking sweet!
pete
Old 03-21-2018, 01:06 PM
  #39
Foxman
Foxman's Avatar
pete
Thanks Pete,
I had no plans for a center console delete. The console went back into the car along with my new RS box (which yielded no weight savings FYI). But plans change ....
Old 03-21-2018, 01:31 PM
  #40
sooner964
sooner964's Avatar
Looks nice! It definitely does open it up nicely without the lower dash pad there. I've wondered about removing mine and replacing the airbag with a glove box, but then I have to think about how to cover all the wiring/venting going on behind the scenes.
How do you like that Blaupunkt Toronto 420BT head unit? I've had that on my short list for future headunit replacement along with a few other units. It looks nice in the car. I like the dual **** layout as opposed to one large **** and buttons. Is it possible to make the facade surround more of a flat black than the gloss black it comes with? I like the Continental units a lot, too.
Old 03-21-2018, 01:56 PM
  #41
Foxman
Foxman's Avatar
Thanks! The lower dash delete was such a great mod I am now planning the same for my 993 (recently called “Tubby” after a corner balancing).
I really liked the sound and functionality of the Blaupunkt. But it didn’t look quite right in the dash to me, and I wanted to lose more weight. I decided to pull the center console out as well. So the radio is now out of the car, replaced with a Rennline radio delete plate. I will post a few photos tonight.
As for the radio, it’s never going back in the car so PM me if you want it.
Jim
Old 03-21-2018, 02:34 PM
  #42
911Jetta
911Jetta's Avatar
Originally Posted by Foxman
With the Steve Wong Chip installed, and Rothsport steering rack and new transmission mount and inserts, I'm beginning to think the car has potential. But Wilbur is a pig, and he needs to lose weight.
Love it! I'd had a bunch of the same mods on my car, plus some of the same weight reduction methods, and it really woke the car up.
Old 03-23-2018, 10:29 AM
  #43
Dru1
2nd Gear
Dru1's Avatar
Totally dig what you're doing with the car. Tasteful!
Noob question here... can I safely assume that as long as the battery is disconnected, you can remove the airbag without (much) risk of setting it off?
Old 03-23-2018, 12:18 PM
  #44
Foxman
Foxman's Avatar
Thanks Dru1,
I’m no expert on airbags, but my understanding is that there’s a resistor that continues to activate the airbag for a a few minutes after disconnect. That makes sense so the airbag can still activate if the power quits from collision. So disconnect the battery, and then wait about twenty minutes to be safe.
Old 03-23-2018, 12:33 PM
  #45
Dru1
2nd Gear
Dru1's Avatar
Foxman, thanks! I'm not afraid of much but those things give me the shakes! LOL
Quick Reply: Chronicling the restoration and rebuild of Wilbur, the Pig
