Chronicling the restoration and rebuild of Wilbur, the Pig
#376
That last photo is my favorite, as you see how the roll bar extends all the way true to the rooftop. Is the sunroof cassette just a crush zone for sunroof designed roll bars? I prefer this setup.
Car feels tighter already
#378
Stock decklid weighs 36 lbs. The carbon fiber lid weighs in at just 15 lbs., for a 21 lb. savings. Nice. Need to weight the struts next.
#381
Thanks Al, those wheels of yours have served me well over the years. Better still, I made a new friend in the process.
I just bought a new set of tires for the 993, and can’t wait for the return to Palmer Motorsports!
#382
Incidentally, cup cars as built in Germany had similar welds there. Rather sloppy work in comparison. Here’s a photo of a cup car with a rather sloppy weld on the pillar.
Cup car cage with sloppy weld on pillar
#383
Speechless, had other plans tonight, but just read through this amazing project.
Well done sir.
Inspirational to say the least.
Well done sir.
#384
Thank you Sir! Good to know that I haven’t put everyone to sleep with this chronicle. Documenting the daily grind isn’t as sexy, but it’s real.
#385
I had a chance to test fit the car this afternoon. The fitment is perfect. At 6’ 4”, my shoulders are right at the top of the harness holes. There wasn’t much room to work with. Total weight of the bar, just 10.42 kg,, or 23 lbs. That’s 40% of the weight of the 57 lb. DAS roll bar, and this cage is far more sturdy.
We removed the struts from the frunk lid, and the carbon fiber lid now fits a whole lot better. Not perfect, but perfectly acceptable for the likes of Wilbur.
Next we we set up the scales for Wilbur’s first official weigh in. Wilbur tilted the scales at 2,607 lbs. Once down from the scales I realized that my tote bag was still in the frunk. The tote weighed 26 lbs. The hood struat took off another 3/4 lb. bringing the weight down to 2,580 lbs. And fhat’s with winter wheels and tires and a full tank of gas. All the weight reduction measures have really started to pay off.
Loaded the seat into the car for a test fit of the shoulder harnesses
Perfect
The offset bar allows the seat to slide all the way back without fouling the seat back
Perfect
Last edited by Foxman; 03-30-2019 at 10:15 PM. Reason: 100 pounds too light on initial figures. Wishful thinking.
#387
Removed the hood struts and carbon fiber frunk lid fits much better with less arch
Threw Wilbur up on the scales.
2,607 lbs., and that’s with a 26 lb. tote bag in the frunk, and the 3/4 lb. hood struts. Total net weight is 2,580 lbs. A good start!
#388
Dunno!
Just asking...
The flanges I've seen are welded to the cage, and then bolted to the car - generally with a load spreader plate or similar.
I had assumed this was for maximum strength.
Wall thickness of cages I've seen are many times the thickness of body pressings, and I would guess a bolted load-spreading flange might decrease the chance of tearing or cracks to the body?
Notably as you're still going to get flex regardless, and assume a bit of wiggle is better than a connection fail where they meet?
Not a cage designer, just a driver here.
Just asking...
#389
Dunno!
Just asking...
Just asking...
#390
Wowzer! It's going to be an autocross battle this year. I've probably got +400lbs on you, but a bit more driving experience. As long as one of us starts beating the gt3/4 crowd, that's all that matters Beautiful welding work!
