Infinite1, good to have you here on the Forum. The only foolish question is the one not asked.
It’s not a must to have insulation under the carpet. The RS came bare bones with a thin carpet and no insulation. If you want the car quiet, then go with Dynamat and MLV. See my RS carpet install thread on the 993 Forum for details. And post pics!
Thank you for the welcome! This forum is such a wealth of information. I hope to be adding my own resto/mod thread soon.....If I can just get out of the drivers seat long enough to start one. LOL.
Thank as well for the confirmation as it's my first Porsche i'm still learning a bit. I'll definitely check out your thread. Noise will definitely not be an issue as I have both the primary and secondary bypass. I just wish i could turn up the volume more...hahah
Great pictures. Thanks for sharing and car is lookin good. Keep it up.
Thanks CBA, how are you liking the new BBS wheels??
Originally Posted by Cemoto
Wow! Outstanding work sir!
I just read this thread from front to back and had no idea you were doing this . . . Congrats!
Bring it on out someday.
Al
Thanks Al,
I was hoping to bring the car to the Palmer's Porsche on the Mountain event this weekend, but it's parents' visiting day at UVM. I am really looking forward to tracking this car at Palmer after the suspension is replaced.
Thanks for all that you and the team at Palmer do to make Palmer such a great a haven for our Porsches, both on the track an off!
Quick update on the ongoing restoration and weight loss program I took the car to Eurotech in Framingham this weekend to evacuate the A/C (for pending /C removal), and to address a few minor items. Proper rubber isolators were installed to secure the DME, pad wear jumpers were fabricated and installed in place of silly wire nuts (the brake warning light was coming on), and the leaking power steering feed hose was replaced with a new hose. It's nice to have one less thing leaking, and the engine bay was cleaned and degreased.
I drove the car home on Monday with a handful of cable ties, and set about securing the remaining lines. I spent an hour under the dash board and in the rear tying off any remaining loose lines. Inglorious work, but necessary nonetheless. Then I pulled out the jig saw and cut a floor board for the passenger side. If anyone wants the templates, just PM me and I will be happy to provide them.
But the best project was a quick replacement of the old lead battery with a lithium battery from Voltphreaks. This is a quick 15 minute project, but add another 15 minutes to clean 30 years of gunk out form under the battery The battery in the car weighed 43 1/4 lbs. The Voltphreaks lithium battery weighs in just under 6 lbs. But add 2 1/4 lbs. for the sturdy Rennline battery mount and the total weight is 8 1/4 lbs. That's a 35 lb. weight reduction, and it took less than 15 minutes to install. Weight is the enemy... Rubber isolators to dampen vibrations for AX duty Removed dumb-@SS wire nuts from PO Cut a passenger floor board Templates saved if your stripping your car This will do Tidied up the lines a bit here
And here Old lead battery weighed 43 1/4 lbs. Found my missing chuck for the drill, Ha! Quick wipe down Lithium battery weighs just under 6 lbs. Add 2 1/4 lbs. for battery mount Quality battery mount from Rennline
Quick, and easy Drops in just like the old battery did. Battery has been sitting in the basement for over 9 months, but the battery remains almost fully charged Topping off with the Battery Tender Jr. This is the charger expressly recommended by Voiltphreaks
Interesting. I was thinking something more aggressive for the surface rust. I'll give that a shot first!
tjb616, you’re right, my error Sir. I also recall hitting it with some polishing compound. Not rubbing compound, just the polishing version. Best to lay a little wax down afterward when using polishing compound, but I just went with some Speedshine.
[QUOTE=Foxman;15332630]Thanks CBA, how are you liking the new BBS wheels??
Love the wheels... I feel the need to clean them after every drive sometimes as they are like jewelry. I always hated cleaning wheels on my other cars but these one are a pleasure. You can see what they would look like on your car. I think you are putting a roll bar in right? If so which one? I'm wanting to do it but afraid of not being able to put my seat back all the way. and hitting my head on it. 6'3". Thanks.
Love the wheels... I feel the need to clean them after every drive sometimes as they are like jewelry. I always hated cleaning wheels on my other cars but these one are a pleasure. You can see what they would look like on yours. I think you are putting a roll bar in right? If so which one? I'm wanting to do it but afraid of not being able to put my seat back all the way. and hitting my head on it. 6'3". Thanks.
Great roll bar, but heavy. The bar behind the seat is offset to allow seats to slide most all the way back. Works for my 6’ 4” frame and long legs.
But going a different route with the 964. Plan is to make our own bar without a transverse bar to keep things light, but still allow the bar to bolt in and out of the car. But first I need to get the sunroof deleted.
10-4 on the DAS.... I totally forgot about your 993 post as I had seen it before. Thanks
Phase II of the A/C delete is complete as I removed the compressor last night. I had to remove the left wheel to access and disconnect the A/C lines inside the wheel well. The project took about fifteen minutes to remove the A/C, and about two hours to clean the wheel well and fender liner. Doh.
Any how the car is is now much cleaner now (still have two wheel wells to clean), and weighs about 20 lbs. less with the compressor and frunk hoses removed. There’s another 2 lbs, to be lost by amputating the A/C bracket, but that’s best done with the engine out.
Phase III is removal of the condenser up front. From what I’ve read I should be able to do this through the left front wheel well with the bottom skirt (in my case splitter) removed. Any tips would be greatly appreciated. Venturing again into the unknown.
Jacked and removed left rear wheel to access A/C lines Thirty years of dirt in wheel well Cleaned up with Goof Off Cleaner and Degreasers
A/C lines disconnected I pulled the rubber seat as well Leaving this nice hole in the wheel well/frunk
