zuffenhaus/ zuchs wheels offset?
hello guys... any chance anyone knows what are the offsets of zuffenhaus wheels that Singer uses? I know that they are 9s front and 11s rear. offset?
Thank you
Thank you
Unless you have the same arches as a Singer, this info would most likely be useless.
Why not use OEM fenders and quarters and have the wheels built to spec?
Hand built cars aren't even identical from the factory. Added flairs certainly won't be uniform to a certain measure. If a tight and perfect wheel/tire fitment is essential to your build, then buying wheels and tires in the specs you want and having the fenders shaped around them isn't a bad idea. Don't even have to be the correct wheels, just the size you will always have built for that car. Can actually be easier than trying to figure out wheel specs with spacers, etc, for a perfect fit, if your body shop is up for it.
No offense, but you've got it backwards. Building wheels is an exact science if you know what you're doing. Hand-shaping fenders is not. Singer arches are carbon composite and the rears are bonded to the chassis.
that's exactly what I am going to do, after getting the desired ride hight, I will build the arches around them.
I countlessly tried calling Zuffenhaus but no one is answering the phone!
Guys anyone has any info please share. The project is going no where without these wheels.
thank you
thank you
http://www.fikse.com/product/zf/
Old thread but I'm asking just in case - Did you manage to finally get the offset measurements?
I'm very much interested in these wheels for my project car and I can't find the offset anywhere to order the wheels accordingly.
17x11 ET+29
17x9 ET+29
I got them from fikse
