Question for the 951 folks (rear brake rotors options 2 piece)
Hey 951'ers.. anyone know of a replacement for the rear rotors that incorporates the parking brake and is an upgraded 2 piece variation. Im a 928'er, but our rear brake system , rotors, are the same. (fronts dont have the same offset , but the rears do) so, do any of the racers here have a solution that provides a 2 piece options ( 2 piece hat that fits our cars)??
Finally in need of rear rotors and the saving of 5lbs per axle is attractive.. but dont want to lose the parking brake.
thanks
Mark
thanks
Mark
Not hard or expensive to get Coleman Racing in the US to make up a custom set. The weight offset from single to double setup isn't that great. Approx 2.2lbs but if you also get rid of the associated hardware you save extra kgs. However some of that includes handbrake paraphernalia. Is the handbrake worth the extra unsprung weight Mark? Also running Coleman setup on the front. Coleman stuff isn't the absolute pinnacle of what's available out there but it's pretty good, very affordable and they make pretty much whatever size you want.
