Stock-height 951 ground clearance under radiator?
Rainman
Anybody with a 951 at stock ride height, could you give me a measurement of ground clearance from the ground to the bottom of the radiator frame?
Rainman
bump...
could anybody with a stock-height 951 please measure ground clearance to the lowest point say in front of the crossmember?
assuming it's the inner sway bar drop links.
locating a FMIC and a big-*** rad fan, want to make sure they aren't going to catch on tall possums.
Rainman
apparently so.
my car's structure in front of the front wheels is all custom so my measurement points are totally different than a standard model.
also, the thing is up on tall blocks right now so it's got 14" or so of ground clearance
just want to make sure the new fan doesn't scrape on driveways and stuff..pretty certain it won't be an issue, as stuff like modern boxsters has 4" or so min ground clearance..
i think the bottom of my fan shroud will be 5.5" or so.
