Ealokens Porshe 951
#122
Clean the hell out of your pan. We glass bean stuff at my work and that stuff is hard to remove and hard to see. Personally I hate the stuff for that. You clean and clean, tack cloth, wash rinse and it still shows up on paint jobs.
#123
im painting it silver.
#125
#129
Finaly the plan is back up, front subframe back up.
Heat wrap installed.
Next up is camhouse And new belts.
Zip ties to hold the sealing in place.
A super trix, took about 3 minutes to Get it in place.
Heat shield mounted
Heat shield mounted
#133
If it was doing exactly nothing, how could it become a restriction....?
I use the same ring....., it lowers the pickup point of suction approximately 1 inch lower in the pan to a source less likely to cause pump cavitation.
The remaining cross section of the uncovered screen is several times that of the suction pipe.
Sustained 6800 rpms on track with stable oil pressure proven.
T
#134
How does it lowers the suction point by 1 inch if suction point is already tke lowest point of the pickup the only thing lower is the mesh Which has recessed space in oil pan. If that ring is welded just the right way it will touch the oil pan arround the recess in pan and actually seal the oil away from pickup.
#135
