Ealokens Porshe 951
Old 08-25-2019, 04:46 PM
  #436
ealoken
ealoken's Avatar
Exhaust done, just some wrapping left.
huge thanks to my buddies that are helping me.
Its_Lobelt (09-10-2019)
Old 08-31-2019, 11:31 AM
  #437
ealoken
ealoken's Avatar
Exhaust done.
DasSilberWedge (01-29-2022)
Old 09-09-2019, 01:15 PM
  #438
Noahs944
Noahs944's Avatar
Geezus, that looks really amazing!!
Old 09-09-2019, 01:18 PM
  #439
ealoken
ealoken's Avatar
Thanks, realy happy with it, crossover and downpipe is out in 10 minutes
Old 09-14-2019, 10:59 AM
  #440
ealoken
ealoken's Avatar
New gearbox project in house, Audi s2 6speed.
will start on this after the car is done now for winter.
Hoping to dyno in October.
4.11 final ratio
1st 3.50
2nd 1.89
3rd 1.32
4th 1.03
5th 0.86
6th 0.71
Old 09-18-2019, 01:50 PM
  #441
JustinL
JustinL's Avatar
Keep us updated on that transmission. It's obviously a bit longer than stock, which shouldn't be a problem for cars with the spare tire well cut out. What about the rest of the case? pretty well bolt on?
Old 09-19-2019, 02:54 AM
  #442
ealoken
ealoken's Avatar
It's a bit longer, but the bolt pattern is bolt on to the torque tube.
I need to fabricate some parts.
New driveshats
Gear link
Coupler gearbox - torquetube axle.
Old 09-23-2019, 07:31 PM
  #443
Its_Lobelt
Its_Lobelt's Avatar
New driveshats
Gear link
@Widerstandsfahig is working on a solution. Maybe you contact him. I'm pretty sure mine is already done. Not sure if you have the same trans though.
Old 09-24-2019, 01:01 AM
  #444
Chapman951
Chapman951's Avatar
Question 1:
What did you do to make it a 10minute installation/removal verses the 2hour OEM? Was a 3 piece cross over used?
Question 2:
Will the new gear box let you reach 200mph?
Old 11-08-2019, 03:23 AM
  #445
ealoken
ealoken's Avatar
Due to a big house renovation the 951 has not got the attention it deserves, when adding upp my no sleep over the oem ignition reading on the flywheel i was on the look for a solution.
DRS Development came up with an adapter wich includes an ATI damper ( good bye balanceshafts ) and a 60-2 trigger wheel.
Adding one camsensor, it`s now a solution my tuner likes.
Might be starting this thing before xmas..
Old 11-08-2019, 01:51 PM
  #446
GPA951s
GPA951s's Avatar
Why didn't you use just an "off the shelf Clewitt?
Old 12-27-2019, 06:36 PM
  #447
ealoken
ealoken's Avatar
So om the waiting game for parts, i starten om refurbishing the ccw wheels.
Old 01-30-2020, 03:09 AM
  #448
ealoken
ealoken's Avatar
Originally Posted by Chapman951
Question 1:
Question 2:
Sorry for late answer, we moved the exhaust tubes so they have greater clearing.
V-band inn and out of the turbo also helps alot.
It will in theory do 310 km/h on 6900 rpm.
Old 02-12-2020, 03:08 PM
  #449
ealoken
ealoken's Avatar
Old 02-13-2020, 05:21 PM
  #450
ealoken
ealoken's Avatar
Quick Reply: Ealokens Porshe 951
