Ealokens Porshe 951
Old 06-19-2018, 05:08 AM
  #346
Voith
Voith's Avatar
Nice progress, can't wait to see end result.
Old 06-19-2018, 07:35 AM
  #347
ealoken
ealoken's Avatar
thanks, hoping to dyno in July.
Old 06-19-2018, 05:54 PM
  #348
ealoken
ealoken's Avatar
Kw3 and 996gt discs and 996TT calipers mounted
Old 06-21-2018, 07:14 AM
  #349
ealoken
ealoken's Avatar
Transmission done rebuild, new bearings, re shimmed and a Quaife diff.
Cant wait to test this one.
Old 06-21-2018, 09:10 AM
  #350
Noahs944
Noahs944's Avatar
Very nice toys! I'd love that tranny.
This cars going to be insane!
Old 06-21-2018, 09:11 AM
  #351
ealoken
ealoken's Avatar
I hope so slowly getting there, but i have to say, without all the help from my friends, i would never complete the build.
Old 06-21-2018, 10:23 AM
  #352
951and944S
951and944S's Avatar
So they totally assembled your transmission, complete with shifter mechanism, , reverse light switch and even inserted mount bolts ready for install and then realized you need to split the gear cluster from the diff housing to install the ring gear/diff....?
This doesn't make any sense at all.
T
Old 06-21-2018, 10:26 AM
  #353
ealoken
ealoken's Avatar
T
Yes, i delivered one S2 Gb and one 951 in parts, was some extra job for him.
But the gearbox is 100% done now.
Old 07-19-2018, 04:02 PM
  #354
ealoken
ealoken's Avatar
Gearbox cooling done.
2x coolers, 0.8L more oil than oem.
going to use omega 690w 75w-90
Old 08-05-2018, 02:56 PM
  #355
Northern porker
Northern porker's Avatar
Are the late offset spindles the same as the standard 968. If so could I have a diagram of the brackets you have made because I am doing the same brake build for my car. Also does anybody know if the 996 turbo calipers have better stopping power than the big reds/ blacks from the 993 tt 928 gts. Great build thanks in advance.
Old 08-05-2018, 03:05 PM
  #356
ealoken
ealoken's Avatar
Are you also running 350mm disc?
Old 08-06-2018, 05:36 AM
  #357
Northern porker
Yes.
Old 08-06-2018, 05:39 AM
  #358
Northern porker
I have also just bought the KW v3 shocks so am interested how you find them. Are you changing any of the bushes on suspension as well. Mo30 roll bars?
Old 08-06-2018, 05:42 AM
  #359
ealoken
ealoken's Avatar
I had a friend to make the brackets, and the "center-spacers" for the brakediscs.
I bough some motorsport late offset arms, new brushings, i already have a big swaybar. The KW`s mounted perfect on the late offset spindles.
Old 08-06-2018, 07:12 AM
  #360
Northern porker
Do you have a drawing of the bracket/spacers you made it would save me a lot of time.
thanks
Quick Reply: Ealokens Porshe 951
