FS: lots of 944 parts I want out of my garage
I need to make space in my garage, please take my stuff! All prices are very negotiable, just let me know if you want something.
factory 944S 16v headers--70
944S2 fuel rail-- 60
Late N/A fuel rail (no injectors)--40
2x Idle control valves--50
set of late offset power inner tie rods, never installed and still in plastic --50
pair of late tan leather seats, ripped, driver side is power-- 100
Working hatch unlock motor-- 20
two tested working early 90 amp alternators--50 each
working rear wiper motor-- 50
951 recirculating valve---40
951 coolant crossover pipe--25
factory Silver 951 rear valance--- 120
4 good used factory fuel pressure dampers -- 10 each
x2 good used factory 2.5 BAR fuel pressure regulator--10
working headlight motor--30
Brand new front cam cover with new gasket, never installed--40
x3 A/C/alternator belt tensioner rod-- 10 each
Pair of early offset aluminum control arm cores in need of new ball joints and bushings---40
set of late front sway bar drop links with bushings and hardware-- 40
set of late caster blocks w/eccentric bolts and hardware--40
2.75"-3" silicone Lindsey racing turbo J boot--60
x2 NA clutch forks with pins and good bearings-- 45
factory scissor jack with handle---50
Other stuff free to a good home:
Factory spring top hats
tons of misc pulleys
water pump cores
water pump cores
