New Race Car Progress
Old 03-13-2022, 02:07 PM
  #151
Max Energy
Max Energy's Avatar
T,
Thank you for your kind and always supported comments.
Going to test fit the Michael Mount 968 motor in next week.
ITB final clearance, plumb up the dry sump and start fitting the oversized radiator
Hope your project is going well. Looking forward to seeing you and Eon at NOLA PCA Race.
Let's talk, I have some questions for you
Max
Old 03-13-2022, 10:40 PM
  #152
Mike Goebel
Mike Goebel's Avatar
Out of curiosity how do the stock spindles tend to hold up to being subjected to that much sticky rubber?
Mike G.
Old 03-13-2022, 11:52 PM
  #153
951and944S
951and944S's Avatar
Mike G.
Never really had problems with spindles, maybe others can chime in on that, but cars looking for a lot of grip are usually very light which lessens the strain on parts.
The shock shaft upper bushings is under extreme load though, more likely to go before the spindle, at which point you are driving/racing with camber varying by multiple degrees.
Worth checking in normal maintenance.
Scary, but not nearly as bad as the ball joint pin snapping at 120 mph at the first turn of an esses section.
Old 03-13-2022, 11:53 PM
  #154
951and944S
951and944S's Avatar
Originally Posted by Max Energy
T,
Max
These days, unless it's PCA SIM Racing, I don't know anything about anything.
You need an at track tech and pit wall guy...?
Old 03-14-2022, 02:44 PM
  #155
Max Energy
Max Energy's Avatar
Mike
We haven't had any issues on the front. We have had issues breaking Rear Stubs, they are breaking at the splines and base of threads
Max
Old 03-14-2022, 07:12 PM
  #156
333pg333
333pg333's Avatar
Titanium Geometry Correct Pins
Originally Posted by 951and944S
The centerline as exist on the stock spindle is shifted during design to raise the wheel hub, thus lowering the car with same geometry as factory.
Yes, to counteract bump steer. I just hadn't heard them referenced as drop spindles before. As usual, Max's parts look like good pieces.
Old 03-15-2022, 12:00 AM
  #157
Droops83
Droops83's Avatar
No, the extended ball joint pins/"drop spindles" are to correct the roll center/suspension geometry with a lowered ride height. The drop pins for the tie rods are there to bring the tie rods back to parallel with the control arms, and also allow for bump steer adjustment with shims, but they are only there because of the spindle height change. I adapted some existing kits for VW GTI and Porsche 911 to make a "budget" version of the same for my 951 some years ago.
Amazing race car pics, keep them coming!
Old 03-15-2022, 04:20 PM
  #158
951and944S
951and944S's Avatar
Exactly.
These were a thing when the lowrider pickup truck phase swept the USA in the 90's.
Old 03-15-2022, 04:22 PM
  #159
951and944S
951and944S's Avatar
Disregard, I see what he has there now in the pics might be confusing.
True "drop spindles" are a complete newly designed part with the wheel hub shaft raised during casting or machining with repositioning of the caliper mount during same.
What he has here is as described by Droops, basically a beefed up extended ball joint pin.
Midwest Motorsports here in the USA does the/sells the conversion for 944s.
Old 03-15-2022, 07:48 PM
  #160
333pg333
333pg333's Avatar
Yes, exactly. It brings the tie rods and control arms back as close to parallel which yes, it does correct roll centres but also has an effect on bump steer.
Old 03-15-2022, 07:49 PM
  #161
333pg333
333pg333's Avatar
That's what I was getting at. Thanks.
Old 03-15-2022, 11:47 PM
  #162
Droops83
Droops83's Avatar
Yes, it would be great if a true "drop spindle" were available for the 944, and instead of an actual spindle, a provision for an off-the-shelf bolt-on wheel bearing that accepts a Porsche-style hub, and a relocated steering arm, with double-shear attachments for the tie rod end and ball joint. But that would be $$$. See below, they are called "uprights" everywhere else in the world!
https://www.brypar.com/product-categ...me-r-uprights/
Old 03-16-2022, 12:16 AM
  #163
Mike Goebel
Shouldn’t it be a raised spindle? 🤯😆😂
Mike G.
Old 03-16-2022, 12:18 AM
  #164
Droops83
Droops83's Avatar
Mike G.
You are correct, but the American term "drop spindle" refers to the type of spindle you'd use if "dropping" or lowering your car, whether it be a pickup truck or VW. Backwards for sure, but a lot of people know what you mean when you say it .
OK, back to race car pics!
Old 03-16-2022, 02:05 AM
  #165
333pg333
333pg333's Avatar
Brypar are pretty local to us down here. Some years back I enquired about getting some custom uprights made. Was quoted circa $4-$5k au. Which would be considerably cheaper in US dollars. Group buy??
Quick Reply: New Race Car Progress
