Guru MAP Stage II help
I just picked up an '87 951 with a Guru MAP Stage II on it. While I was poking around under the hood, the two wires that hook up to the AFM came off. I, of course, have ZERO documentation on how to reconnect them. If someone could post or PM me with the proper connections for me, I would greatly appreciate it.
Regards,
Regards,
Nope, sold the '86 to a friend of mine that needed some serious "boost" therapy.
So its just three, not four (um, for now, anyway...).
Regards,
Regards,
Plug them to the outmost sockets, numbers 1 and 4 (5 is unused in the connector). It might be a good idea to wrap some tape around the thing to keep them from coming off...
Thanks, guys! That was the info I was needing. I have a connector from a dead AFM that I am going to solder the wires to, so that I have a decent permanent connector for it. I wasn't impressed by the two spade connectors plugged into the AFM lead, altho I would be hard pressed to suggest where Danno (or anyone else, for that matter) would be able to find a matching connector short of pirating parts off off dead AFM's like I did. Also, I am assuming there is no polarity issue on the temp sensor, right?
Does anyone have a set of instruction/documentation package from Guru for the Stage II set up that I could copy? I have gone to the Link USA web page and downloaded the info I could find there, but I would like to complete the documentation set, if possible.
Regards,
Regards,
Thanks Sami! For some reason, I wasn't able to find get that link to work on Danno's site last night. Now, of course, its working fine... lol
Regards,
Regards,
