Which pistons are you using? I can get you custom JE in around 2 weeks, and I have all the 4V dimensional data. Let me know if you're interested.
Michael
I know you're a fan of this intake and clearly it has a proven success via Gustaf's own motor. What is your impression of it for a street car with stock cams and lowish c/r for a 16v head?
Originally Posted by refresh951
One disadvantage to this motor is that it is not a Hybrid Stroker so the pistons are custom and they will not arrive for about a month. My friend had many of the components already so we are building around them. Still, it should make for a very fun street car.
Shawn, is this head fully stock ie valvetrain etc?
This is going to be a great E85 street motor. The Variocam will be a cool feature to go along with the short runner intake. I am looking forward to testing it as the Variocam will be Arduino controlled.
Michael cleaned up the ports, rebuilt the head and modified it for the 2.5L block. The valve train is stock 968.
I will always be willing to give up a bit of bottom end on these turbo motors by keeping CR lower. Even with the stiffer 16V head, I have seen evidence that these heads move around quite a bit. Sean is running 8:1 CR and still replaces his cometic every year IIRC.
Hi, looks good. Did you source the pistons from M.Mount or did he supply the specs to order from JE direct ? I am looking for some 16v pistons for myself. Thanks.
