Early water pump question
Oh, so you are planning to remove the cam sprocket to replace the seal? If I remember correctly use the cheesehead tool for the cam bolt, and there is a large nut on the sprocket you put a big wrench on to use for leverage. I do not think moving it a few mm during that struggle will really destroy anything. If the cam tower is coming off anyway for seal you can remove the cam on the bench but leverage might be more difficult. Make sure to replace the cam bolt , anything cheesehead replace without question.
Yes, one of the FCP kits includes a cheesehead bolt.
Did you pull the rad to get more room to work?
I still think its safer to loosen the cam gear wile the belts are on. That way there's no risk of hitting valves if I slip. I know I will slip if the penalty for slipping is bending a valve. That's Murpjy's Law 101.
Regards,
doug
86 951 (http://pcaucr.org/media/image-galler...ll&gallery=224)
01 E320 (W210) 4matic Wagon (http://www.benzworld.org/forums/w210...body-do-2.html)
00 540i-6 (http://forums.bimmerforums.com/forum...hp?albumid=976)
94 855 turbo Wagon (sold in 09)
85 535i-5 (sold in 07)
76 300D (sold in 92)
83 944 (sold in 86)
I apparently only buy cars designated by numbers
Regards,
doug
83 944 (sold in 86)
Regards,
doug
83 944 (sold in 86)
Regards,
doug
83 944 (sold in 86)
