Something New...
A great display to use for these arduino projects is
http://www.4dsystems.com.au/product/uLCD_43DT_AR/
They have a 3.5" version for $100. I have used these at work and for home projects. Real easy to get started and has good libraries for the Arduino. You can get them several places here in the US. Here are a few pics of my displays using it:
That's a great looking display (if a bit pricey). I'll keep mulling options for the display. The one I'm using serves it's purpose, but is fairly bling-free. The project is still a work in process and I have a few more interesting things to add, so not quite ready for prime time. I'll update as it evolves and always happy to help others on a non-commercial basis building similar projects for themselves.
Professional Hoon
So funny you say that. I was tempted when I ordered this LED, but they cost more and I figured I'd go with something simple until I had it all worked out. Do you have any pictures of your OLED screen in action, and does it combat sun glare when driving in the day? That alone would push me over the edge...
Then again, The product and technology used in the screen on the PLX is now quite old. so it could be better, better res and contrast ratio IMO. But for what it is, I'm happy with it.
I'll get some pics tonight. I have crappy phone pics only.
Because i have mine behind the plastic from the 968 clock, it has a bit of glare. And the screen could be more brighter. It is at times hard to see during the day,
Professional Hoon
The unit itself is great. so much data. very customisable.
I'll put up a thread tonight.
Which brings to mind the following question:
From a monitoring standpoint, which engine parameters could be ported to something like this?
Coolant pressure is good.
Oil temperature?
Intake pre-cooled and after intercooler temps?
Not sure I appreciate the importance of EGTs...
What else?
Oil temperature?
What else?
Professional Hoon
Oil temperature?
What else?
Oil temperature?
What else?
Oil pressure,
Oil Temp
Water Temp
Water pressure (if you wish to)
intake air temp. (as many as you want. pre / post IC. Intake manifold. ect.
boost/vacuum
EGT 1,2,3,4
AFR.
Well done Tom!
Funny how things snowball. I originally just thought a panel from front panel express would be cool there instead of the ashtray (or my cupholder thing). Then I thought I'd add a coolant pressure gauge, then figured I might as well add some other things... My thought was not to log, since there are so many other ways to log these days, but rather as a place for data that's useful after the fact and doesn't usually get monitored, but we'll see. And I'm actually working on a few more creative ideas for this, but not ready to share yet It's the kind of project that could easily be killed by scope creep, my Achilles heel...
Professional Hoon
If you make something to fit the 968 cubby, i think that would be ideal for a few!!
That's basically what i was trying to achieve with the PLX.
Or a whole screen (single din) for under the HU. OLED. full of parameters and some eye candy. Bit more work involving that though.
