Coolant leak
Our '86 951 has developed a bit of a coolant leak right at the bottom front of the motor, by lower balance shaft sprocket. From the picture, I know it looks brown like oil. But trust trust me, what winds up on the ground is green coolant. I have a very slight oil leak in this region as well, that predates the coolant leak. It was so minor (one or two drops a week), I was not ready to do anything about it (I'm thinking lower balance shaft seals?). The coolant leak is not bad, but it has grown from one drop a day to maybe 6-8 drops day (about a quarter sized spot) over the last couple of months. I don't expect it to magically cure itself.
I know the water pump is the likely culprit. But, the pump was replaced 2 yrs/12K miles ago as part of a t-belt change. I can't imagine that this is leaking already? My question is, other than the pump, what else could be leaking coolant in this area? (all hoses/clamps have been checked).
Thanks.
Roger
Thanks.
Roger
Nice photo, looks just like mine lol, though I think for me its a little powersteering fluid / oil leak combo.
good luck on the search, actually one idea would be... do you have one of those Stant pressure testers for your coolant, I found that to be an awesome tool for finding leaks and bleeding on a cold engine.
Quit Smokin'
The oil filter console is right above that, and it covers a giant water passage into the block. If the seal failed there it could definitely leak coolant to the outside. The much worse leak in that area is to have the oil passage pipe seal fail and leak coolant into the engine. I'd be pretty surprised if your pump failed that quickly, but you never know, especially with remanufactured parts. Rent a coolant pressure tester from one of the autoparts stores and pump it up to 12psi and keep your eyes open for leaks.
Roger
Quit Smokin'
There are a couple write ups on it. If you remove the exhaust manifold you don't need to mess with the power steering. If you leave the exhaust in place you must move the power steering pump out of the way. I've done it both ways, plusses and minuses to each
Check the bleed screw on the water neck and the associated seals as well. 4 bolts hold it in place. 2 visible and 2 hidden under adapter plate. That's where mine was leaking which drained to exact same spot as yours.
Roger
Exactly. Don't forget the bolts that hold the neck to the head and the gaskets. My leak only showed up under pressure.
Let me know if that was the source of the leak.
Thanks.
Roger
