928 4V head for turbo question.
Old 08-25-2015, 10:31 AM
  #46
V2Rocket
Rainman
V2Rocket's Avatar
thats a really big chamber.
nice project!
Old 08-25-2015, 07:01 PM
  #47
Hilton
Hilton's Avatar
Originally Posted by Humboldtgrin
This one may be more accurate. I searched more numbers. What is the cc of the turbo piston? 25.7 or 33? If it's 33 I just dropped below 7:1CR not good. Would have to buy Wiseco 25.7cc 8:1 turbo Pistons.
Interesting project
This thread by a reliable technical source on the 928 forum has the various piston volumes for 944/951/968 and 928 models, as well as head volumes for the various 928 heads:
https://rennlist.com/forums/928-foru...c-numbers.html
951 pistons are 25cc apparently, as are early 928S4 pistons (87 to midway through 88MY) which will also have the 4-valve cutouts in them already and are also 100mm (951 ring packs fit them).
Erkka also cc'ed the 928 S3 heads (85/86 32V) as 56.5cc so slightly smaller than your calcs.
Old 08-25-2015, 09:17 PM
  #48
Humboldtgrin
Humboldtgrin's Avatar
Awesome!!! Let take a look at the new numbers.
7.53CR not bad!
Old 08-26-2015, 12:09 AM
  #49
Humboldtgrin
I has thinking Porsche gave us all the parts to make a modified version of the 81 la mans 944 turbo race car 2.5 DOHC engine. Someone needs to copy Porsche's equal exhaust headers!
Realy nice exhaust!!!!!
Nice intake.
Old 08-26-2015, 12:28 AM
  #50
Humboldtgrin
So if you take SFR stage 2 exhaust runners 3 and 4 then take broadfoot racing's stage two number 1 and 2 exhaust runner you will have what Porsche came up with in 1981! And your heat shield for your oil filter can still remain untouched. Bonus!!
Old 08-26-2015, 02:18 AM
  #51
333pg333
333pg333's Avatar
Or you get some made up.
Old 08-26-2015, 07:48 AM
  #52
blade7
blade7's Avatar
Depends where you want your power/torque output.
Old 08-26-2015, 09:58 AM
  #53
Voith
Voith's Avatar
Nice welds. I hope it is not too hard to weld like this.
Old 08-26-2015, 10:53 AM
  #54
Humboldtgrin
Those are exactly like what I want to do! Very very nice!
Does anyone know what the CR of the 81 la mans 944 was? I've searched and found nothing.
Old 08-26-2015, 11:53 AM
  #55
Humboldtgrin
333pg333 there is only one thing I would change on the header setup, I would have them more oval running under the oil pan for more clearance due to the heat generated. And a bigger pipe if the oval design restricts it too much. And I would white lightning the exhaust and oil pan also. Has anyone used jet coat or white lighting on the oil pan yet? Looks like it would help a lot to reduce heat transfer. Everyone talks about oil coolers so I was thinking of another way to cut down heat for the engine oil. I'm sure someone has.
Old 08-27-2015, 10:28 AM
  #56
ramius665
ramius665's Avatar
I personally would try to get as close as possible to 9:1 compression for good off-boost performance. With 951 rods and cast 944S pistons, you should be able to safely run up to about 16-17psi of boost. Racerboy's thread shows you can get very close to 400hp with relatively mild mods.
Old 08-27-2015, 11:08 AM
  #57
V2Rocket
Rainman
V2Rocket's Avatar
having such a big chamber and low CR is attractive to me for a potential blower-motor build...what do you mean, 'off boost'
please make an old-school turbo monster! and remember the old 930 had something like 6.5:1 cr so your plan is a step up
Old 08-27-2015, 11:21 AM
  #58
Raceboy
Raceboy's Avatar
It is 400hp at the wheels. And that was with boost leak and hot dyno room. At 20c evening VirtualDyno showed 447 whp (during dyno run, VirtualDyno showed 389 whp, Dynojet gave 393 whp, so it is quite accurate).
Old 08-28-2015, 12:47 AM
  #59
AlphaOmegaPower
AlphaOmegaPower's Avatar
I agree with this completely
Old 08-28-2015, 01:21 AM
  #60
Dave W.
Dave W.'s Avatar
I'll vote for higher compression plus a good tune.
FYI the early version of the 930 did not have a knock sensor, so it needed low comp ratio just to survive.
Quick Reply: 928 4V head for turbo question.
