Motor mounts need assistance please
Rainman
https://rennlist.com/forums/996-foru...em-mounts.html
This is what we used to do prior to semi - solid transmission mounts. It's a straightforward deal, and worked very well. One of the best options if the money is an issue, plus you'll learn how to do the job moving forward. It's not that difficult, a good friend, jackstands, and a floor jack will make your bloody knuckles, dirty nails, etc. easier.
Semi-solid mounts for ~$100 all-in.
I may do mounts on my car sometime this year and might give it a shot.
[QUOTE=George D;12518702]Check out this Rennlist post in search. Budget - this may be your solution.
Sounds familiar to what spencer did for the transmission mount.
https://rennlist.com/forums/944-turb...ion-mount.html
Porsche acronym:
"Poor old retard should cut his expenses"
And top reman taste way better then rice alone. Top reman gets the little tasty packet. Buy vitamins and supplements if you plan on either of these diets. A car is not worth starving for. Unless you have mental problems such as myself. Then it's ok, you'll eventually eat, but don't forget those vitamins.
