Brake line failure on track - lucky I'm not dead
#32
Yes, stick with OE brake hoses, either from Porsche or their OE suppliers (like Ate). I buy them from Porsche because I know that if they fail (and I've never seen one fail that was properly installed and life'd), Porsche will stand behind the part and take care of me.
Teflon does degrade with time, what doesn't, why would anyone say anything so ridiculous? One of the great dangers with s/s hoses is that it can be impossible to see degradation of the hose, in particular at the fitting, because of the braid cover. Not that people who install them typically ever check...
I have no issue with Goodridge products or their use on dedicated race cars by experienced mechanics. I have issue with the idea that they get installed by well meaning people who don't understand how to properly install them, don't ever inspect or replace them, and don't understand the risks. "Rubber" hoses show their age: swelling, cracking, etc. before they fail. Tefon hose fail about 3 seconds before you hit a tire wall or a kid on a bicycle.
#34
Looks like OP's lines were from this chinese factory: http://yuelonghose.en.made-in-china....uning-use.html Craig, what is the price for a set of good, proven quality goodridge lines for 44 turbo S?
#35
Goodridge is a top tier brake line manufacturer. The Lifetime warranty is hopefully a marketing deal, as all brake lines used in Motorsports should be considered a disposable/replaced wear item. Their clear line kits may be my next set up front. Rears don't have flex lines, just OE stainless tubing with a rubber coating, not much going on back there but power transferred, and good squat.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Like the www.rennstore.com site. Is this part of Rennlist? Really like your Girodisc rotors. Never heard of these till I went to your site. Neat information, and my next set of rotors.![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
G
G
#36
#37
Our cars have tandem master cylinders, which separate the front and rear circuits. The idea is that with the pedal depressed, the front and rear circuits are isolated. If something goes wrong in one circuit, like a hose failure, the other circuit is intact and can provide braking. However, you have only that circuit's brakes working for you. On the street in a non-critical situation, the odds are that you can slow or stop the car. In a critical street or I would imagine any track situation, you'll slow but not enough to avoid an unhappy outcome.
