Ghetto IC modifications
Old 09-15-2003, 09:58 AM
Sami951
Sami951's Avatar
Default Ghetto IC modifications
Looking at a 951 stock intercooler it's obvious there's a problem with the incoming end tank. If it's a design fault or done on purpose (the 951 couldn't be faster than the 911, remember?) we'll never know for sure ...
Lindsey racing does this type of modification for their stage 1 intercoolers, but since we're on the wrong side of the pond, it proved more cost-effective to get it done locally. Here's the first version:
Just compare the end tanks. Sure, our version looks ugly, but it's also a lot bigger...
I volunteered my car as the test mule. Here's Pete making space for the modified cooler (had to get rid of one mounting bracket, and re-locate the other one)
Seems to fit in reasonably well...
And looks completely stock once everything is in place
Too bad we don't have any hard data on how it performs, but we did go for some open track driving yesterday and measured intercooler outlet pipe temperatures by (a very accurately tuned) hand every time a session ended (my car vs. Tommy's 951S)... surprise surprise, there really was a difference! Of course there are a lot of open variables like incoming air temp, driving style and so, but I'm confident that once we get to hook up some real temp sensors, we'll get positive results
Old 09-15-2003, 10:11 AM
Russ Murphy
Russ Murphy's Avatar
It looks like a job well done (and worth doing).
Old 09-15-2003, 12:18 PM
TurboTim
TurboTim's Avatar
If anybody here in the states is interested in the same thing, we can do it for $200US.
Old 09-15-2003, 12:22 PM
Jason_86_951
Jason_86_951's Avatar
Tim,
Will that price be good in a few months? (when it starts snowing)
Jason
Old 09-15-2003, 12:32 PM
streckfu's
streckfu's's Avatar
Very cool, Sami. Nice job.
Tim,
Is that the price for sending our IC to you?
Old 09-15-2003, 12:35 PM
TurboTim
TurboTim's Avatar
Tim,
Yes.I will see if I can scrounge up some cores so that we have them here.Ofcourse if we do this there will be a core charge:^(
Tim
Old 09-15-2003, 12:42 PM
evil 944t
evil 944t's Avatar
How about testing the mod and putting some before and after temps on the board before evrybody starts throwing $200 around. It may help or hurt you, you never know.
Lindsey may do it a little different. They test and post numbers.
I'm not knocking your work Tim, I just don't want to waste money.
Old 09-15-2003, 01:11 PM
Bengt Sweden
Bengt Sweden's Avatar
I expect the real benefit will be flow improvement, not cooling efficiency. If you then flow more hot air through the cooler, temperature may actually rise! To compare I guess you can measure the AFM output at given pressure and rpm.
Bengt
Old 09-15-2003, 02:27 PM
streckfu's
streckfu's's Avatar
Take a look at the Lindsey site. They list temp differences between the the 3 stages.
Stock temp is 251 temp out is 109. drop: -142
Stage 1 temp in is 268 and temp out is 98.5. drop is -169.5
Stage II temp in is 263 and temp out is 112. drop is -151.5
And they advertise that the stage V flows 75 cfm and drops temp by 40 degs over stock with Spearco core.
That's off there website.
I'm pretty sure there's no real gain with the stock turbo but gains will improve with a larger unit.
Old 09-15-2003, 04:15 PM
Sami951
Sami951's Avatar
I'll post numbers here when we get some, but don't hold your breath since this is just a hobby after all ...
Old 09-17-2003, 02:23 AM
Olli Snellman
Olli Snellman's Avatar
It's my IC Sami is testing right now. IC modification is only one part of the modifications there will be in our cars. There will be MAP kit, dual port WG, test pipe, upgraded turbos etc etc. I suppose all these together will give us a little bit benefit
Old 09-17-2003, 02:33 AM
Ahmet
Ahmet's Avatar
I'm not sure how much of the flow restriction that end tank ends up causing. I'm inclined to think that the long internal passages for the intercooler is another significant cause of pressure drop.
On the otherhand, improving that end cap that's clearly more restrictive than it needs to be can't hurt, and you get to retain the stock look. It also looks like good work. I would be interested in some numbers as well, if you ever get around to that.
Good luck.
Ahmet
Old 09-17-2003, 02:34 AM
nine-44
nine-44's Avatar
I think it looks good guys! Keep playin with them.
Old 09-17-2003, 02:57 AM
Olli Snellman
Our group (4 cars) would like to keep costs down, that's one of the main reasons we did this mod locally.When you buy parts for 4 cars you usually get good discounts.Our group also helps to avoid "down-time". My car will be back on the road again next summer, so my friends use my parts when their own are under work.
Old 09-17-2003, 05:37 AM
NZ951
NZ951's Avatar
Can I be part of your group? And you guys move to New Zealand?
Quick Reply: Ghetto IC modifications
