Rogue tuning
#31
Did it ship yet? I'm still waiting for mine, haven't got any shipping notices yet.
#33
Are you guys talking about VEMS plug&play ecu? Which connects steaight to the original dme klr harness and has basic map so your car can run? Which has bluetooth and aps so you can adjust maps on the go or on dyno? Yes I heard about it lol and its ~1200 $ ¿?
#35
+ Injectors, air filter, intake tube, and plenty of 944 kits in everyday use on the street ?
#36
No need to change the injectors, AFM can be replaced with hollowed out one to retain factory look, just needs air temp sensor (included) to be installed into charge tube, nothing else.
#39
Rainman
It looks like junk to me, besides the Bluetooth option. It has other connectors from different ECUs that happen to fit the 944, it has exposed wires to convert that plug to the one the ECU is designed with. Visually is pretty big, maybe thicker then the stock dme. And I'm pretty sure its not using 3 dimensional mapping. It's just a more convenient stock dme, for basic tuning. . I'd say rogue tunings ECUs makes that ECU look outdated and at less then half the cost, I'd say no contest. Rogues design is by far the best ECU on the market
#41
VEMS is proper standalone based on megasquirt, rogue is clone of original ecu with few extra options.
Vems is not junk trust me. Their webpage and documentation is mediocre but ecus are good.
#43
#44
Maybe you should get more familiar with it before throwing such statements? VEMS has one of the best tuning interfaces in the market, not just in its price segment. Ever heard of Alpha-N+hybrid load control strategy that is best for ITB+turbo application?
Feature-wise it is comparable with Haltech Platinum 2000 only costs fraction of the latter. Also, it supports 8cyl full sequential injection/COP ignition, also dual-VANOS (and other cam control types) + electronic throttle.
Regarding derivative from MS, that is not that way for at least 7-8 years. In its eraly days it used Megatune interface (that was not compatible with MS, they use completely different CPU architecture), for last 7-8 years VEMStune is the interface with all features integrated.
#45
