ECUs are being built in batches...
Orders on the website puts you in the queue. I'll update the site tonight to make that more clear.
fast924S, you can send me an email about modifying your tune.
If I order one say next week, how long would it be until the next batch is ready roughly? I have a spare ecu. So a wait isn't a big issue. Though I noticed the fqs switch in mine is blue. Does this matter? I believe its from a late non turbo
I'm building my neighbours 86 951 right now also. I'll try to convince him to buy your ecu to add one more to the batch if needed Well see how it goes tonight when I check with him.
The FQS switch doesn't matter... Technically, we can't use the blue one, but we did get the original manufacture of the brown-style to do another batch for us.
Rogue
Can your ECU interface with the DME logger without having to cut the wiring harness open (is there a plug already on the new ECU)>
The logger only requires one wire from the DME (pin 12), and a ground.
Pin 12 has no other function.
The new ECU doesn't provide an alternate pin 12 input.
