How much HP can i get out of a 944?
#31
Professional Hoon
With the stock turbo, you may get 400 hp, with about 30lbsof boost, right before it blows the head gasket and starts throwing rods at you like a freaking howitzer. It you are using the stock turbo, your other mods are irrelevant, so you may as well just add a real boost gauge and a manual boost controller, and turn it up until it blows. Then build a high hp car with a REAL turbo.
PS and READ! The amount of info available here will answer your question a thousand times over if you take the time to read it.
#32
#33
