Weird voltage thing
In my 86.. the voltage gauge reads about 13 usually but every few minutes there is a very loud hum from the right rear - I assume fuel pump. It strains very hard for about 10 seconds, then goes back to normal, which is silentand working fine. The car has no apparent fueling issue and starts and runs decently all the time. When it strains, the voltage gauge goes straight to the red. All the way to the top of the gauge. The car does not stumble or anything else during these events. I do hear a significant whine through the stereo during the event. It's a small head unit with no amps and just two door speakers, and it has zero whine any other time. I don't know a lot about electricals.. but it seems that if something is running extras hard sometimes, then the voltage would drop like when other things run such as the windows, lights, not skyrocket. Thanks as always.
Your electrical problem sounds unusual. If it is the fuel pump, I would check the ground and power connections at the fuel pump to make sure you have good current continuity. The wires to the pump are somewhat light in gauge, so any poor connection will result in the pump seeing lower voltage, which results in higher current draw.
Could it be the voltage regulator in the alternator? There really isn't anything the fuel pump can do that could cause the voltage to go so high. If the pump were to somehow slip, it would draw less current, and you might see the voltage go up *slightly* (though probably not), but the regulator should be limiting it to somewhere around 14v, even with no load. Plus, you would also have poor fuel delivery in that case. On the other hand, if the voltage from the alternator goes up a lot, the fuel pump will speed up and that could explain the noise - but it would not cause a fuel delivery issue because the pressure is regulated at the rail.
It would also be wise to check all of your electrical connections between the battery, starter, and alternator, both power and ground. Of course the voltage regulator can and will fail on its own, but loose, dirty, and/or corroded wires and connections will result in the alternator working overtime to maintain battery voltage, thus causing charging system failure.
Problem solved... the FPR (stock) was bad and causing some flow issues in the fuel loop, and causing the pump to have to work super hard, causing massive voltage spikes. Replaced FPR and has not done it since ; ) Thanks
Interesting find. I wouldn't have guessed that. What made you think fuel pressure regulator and how did you test it and rule out the damper? Fuel pressure test? Congrats on fixing it!
Nope... problem not solved.
I thought of the FPR because when it fails it might cause some straining in the fuel pump since the fuel pump is next behind it in the line of fuel flow and pressure. And I refreshed my motor including a new FPR and the problem was gone for a bit. But that was just coincidence as the problem is back now with a vengeance.
Follow on thread: https://rennlist.com/forums/944-turb...-part-2-a.html
