swapping an N/A motor into a stand-alone 951 and boosting it- feasibility groupthink
Did you run an NA headgasket on that 10 psi motor? As far as the internals, as others have noted some 951S had factory cast rods and so do many boosted S2's, with a good E85 tune and 10-12 psi of boost, it should last a long time. The NA ring pack is the same as the turbo cars I think, so no trouble there under boost I wouldnt think if the NA motor has good compression and doesnt burn oil (so long as it isnt detonating).
I run a KnocksenseMS unit and let megasquirt retard timing progressively if it detects knock. What fuel were you running, I'm assuming pump fuel? I'll be running E85, I detected no knock on my 8:1 951 engine at 22 psi (it died a violent death because of a failed factory rod bolt on a stock, never opened 100k+ miles engine), I would think my 9.5:1 motor should be fine on 12-14 lbs. I dont think the difference in compression will make a whole lot more power than the 951 motor if we are comparing equal boost levels, so at 14 psi I should be well within the structural integrity limits of the rods and pistons.
Lol even weaker engines are turbocharged every day that run higher boost and more power, 944 is nothing special. For example stock S2 pistons can withstand 670hp, just a hint
I say do it. I wish I did it years ago when I first took the engine out of my 951. I'm almost done rebuilding the engine... but I could have been driving the car all of this time. Even if it's only 5 psi, or NA, it's better than paying for storage.
I'm rebuilding my '87 turbo engine using a donor '85 NA block. As far as the oil filter housing, I just put the one from the '87 turbo onto the '85 block and used the '85 OPRV (3-piece). I used the factory alignment tool for these early OPRVs when tightening the housing bolts.
I am using the 951 internal parts, but I have read many threads where a complete NA short block or long block is used in a turbo application (951). Look up a thread by DanD, he made it work years ago and loved the extra pep.
Side note, 968 rods are not the same as the cast 944/S/S2. They are sintered (forged) but narrower (and lighter) than 951 forged rods.
Unfortunately guys this never came to pass, I'm still open to the idea if a really cheap N/A long block presents it's self to me. Does anyone want to donate cheaply an N/A engine for the cause
I have a good, complete 16v head w/ cams & valve cover ready to bolt on, just could use new tensioner pads. I'm trying to not part with it so I can use it later, but I also realize it might be better to sell/trade it in the short term in order to get my 951 running again, vs making it a super long drawn out process building my dream motor. I have 16v headers w/gaskets + spare crossover easily modified to fit 16v headers + fuel rail + belt rollers too and some stroker misc engine parts suited to stroker use like a block w/matching balance shafts and girdle + two cranks + a 951 head and a set of 4mm oversize intake valves cut for stock valve keepers.
Rainman
what's stopping you building the stroker as-is?
if you want to do a 16v motor you may just be better off keeping the parts and finding money otherwise.
i sold a complete 16v head recently, with cams, springs, lifters, and exhaust manifolds and only got $500 for it. not even a whisper of interest over that price, on 2 forums, facebook group, and ebay.
Rainman
you could buy my already-sleeved block that needs an overbore.
https://rennlist.com/forums/944-turb...ved-block.html
