Dynoed my car
Have you measured cross-over pipe back pressure at all? Just curious if you did what you are getting.
My T4 0.68 on my super 75 is very close to 1:1 at 18psi boost the other day I was at 20 psi back pressure.
Temp was only 3 degrees Celsius
No. That's part of the reason why we did not push any further. My tuner said that often when the head flowed very good like the 16v head does. A small housing will make a big impact because so much exhaust will revert back in to the cylinders. He were pretty confident that a .81 would really open up the motor
You really think a T4 .68. hotside is too small? I'm not convinced. There are many supras running far more power by far on a .58, which is what I run and I'm making a bit more power.
I'll deliver the car to the new owner today so my time as a 944 owner is over. ☺
Godspeed!
For what it's worth both the S2 and 968 feature dips in their officially-published factory torque curves. In the case of the S2 I would think it may be caused by a "restricted" tune, as the long runner intake should provide great ram effect between 2.5k and 3.5k rpm, where the dip occurs.
Do you mean you have some kind of overboost protection that may have kicked in at the moment of the dip?
Is level 3 based on 951 or 2.7 head?
I do get a slight spike about 2-3 psi higher which I am positive is the wastegate opening then settles to say 20psi if the contoller is set to 18.
Last year I was seeing 17 and 20. May have been the cooler temps not certain if that could be why. Some of the experts on here might know
The dump to atmosphere really helps I am sure.
