Installing my M-Tune, a couple quick questions
#31
Went for a quick spin again over lunch and couldn't be happier. Because my car didn't run right before (barely ran at all cold, died under moderate load or when coming off WOT) the difference is staggering. It's finally the car I was hoping it would be when I first picked it up last year. So smooth and the power won't light your pants on fire but is more than adequate. It makes the prospect of pumping money and time into it over the coming years to get it nice seem like a much more appealing proposition. I took a co-worker for a spin and he couldn't get over how much better the car was from before. Just had to share the joy.
#35
#36
#37
One last thing, you wouldn't happen to know which wire it is from under the dash would you ? Might be much easier to cut the wire from under the dash and run a new wire out from there, that way the connection point is inside the car and safe from weather. Just a thought. If anyone knows which one it is that would be awesome. (Cycling valve's keyed power wire, or pin number on the computer harness) I would assume it runs to the DME or klr harness and could be fixed from there.
#39
From: Encinitas, ca PCA National DE instructor PCA San Diego chief driving instructor
I have Josh's tunes on both my 951s, a pristine '86 street car and a highly modded '89 tack car.
They don't just have better driveablility, the power band is wider which means better lap times.
Now if I could just get the logger software to work.....
#40
Quit Smokin'
I just installed mine over the weekend and love it! One thing I'm not sure about is how much boost the thing wants to run. Is that the point of the Map and Maf, you just set for the boost you want and as long as the injectors can keep up it will figure the fueling out? I had originally been looking at the Lindsey racing MAF and they were going to want to know what turbo I had to flash the chips... for the M-tune all they cared about was what injectors I wanted.
#41
I couldn't be happier after two days of driving mine. I can't wait to burn up the rest of this tank and try the E85 tune! Of course, I leave town for two weeks on Friday... it will be a LONG two weeks.
#42
#44
