Alusil Cylinder, how should it look?
#31
I think it was done to keep the air turbolence down so that flow trough new ports is smoother.
In turbo application it makes more sense to let those spaces to cool with oil than to leave them to heat up more than water cooled part of cyl.
#32
For the record, part of KS manual with AluSil info.
#33
Blade 7 . There is a reason as to why I built 944 spec engines in San Diego and why I now work in the Vehicle Engineering Test Group at Tesla Motors
#35
Thats why I am here. To learn.
#38
Seriously, though, any tips to share on using snap gauges to measure piston clearance? I couldn't do it. Bought a .0001" dial bore gauge on ebay (Starrett 84) which was much easier to use.
#39
I find them tricky to use, making sure you are at the largest dia of the bore and locking it off it seems easy to read under. Trial setting the gauge in a mic or vernier until it fits the bore seems easier.
#40
Smaller bores are easy, 104.5 not so much.
#42
Better safe than sorrow. I will do the lapping part myself, manual says it it self limiting procedure so Id rather see silica is more exposed than less.
#43
Havent seen the first one, Ive read other two trough and much of the KS AluSil manual.
Second link you posted contains this:
I will gently rub AN-30 in it for another minute per bore.
The final exposure step requires a new specially developed, elastomer-bond abrasive (XM27), using light honing force. For the exposure step, we recommend tooling with the greatest abrasive surface contact area. This step is based on time, typically 1-1 ½ minutes for 19 µin. (0.5 µm) exposure height. Longer cycle times are not harmful, because the process is somewhat self limiting. It is absolutely critical that honing force or pressure be kept as low as possibly, while still maintaining tool stability. Surfaces shown in the accompanying illustrations were honed with less than 5 lb/in2 pressure.
#45
