JE pistons, used, for 101.6mm (4.00") bore/stock stroke
Rainman
Cross-posting this from the FS side to clear them out.
Pistons are in good shape, just need a cleaning and new rings.
Only for use in sleeved bores - intended bore is 101.6mm/4.00" but have your shop double-check the measurements before fitting.
Stock-design crown/pin height, will work with stock crank/rods if your block had scratches on bores.
First $150 takes the pistons, including shipping in the USA.
https://rennlist.com/forums/for-sale...44t-951-a.html
Are you selling those rods too Spencer? If so, what are they?
No worries, thanks. GLWS. :-)
Freedom Enthusiast
This place is all about timing. There were two sets of Wossner S2 rods for sale here on RL just a few weeks ago. Both are now sold. I'm sure others will come up at some point.
