Catch cans and crank pressure
#241
I have learned over the last few days that those who want power brakes if the engine dies will also mount a vacuum canister with a 1 way check valve to store vacuum. If I'm happy with the function of the pump then later I will add this to the car. Total cost for the canister, pump, switches, etc might be $300 US. It should reduce leaks and help with power & hopefully help drain turbo oil (the reason why I'm installing).
#243
Search this forum for Saikou Catch Can and you should see multiple pictures of how to hook-up a "closed/non-venting" catch can.
https://rennlist.com/forums/944-turb...lling-aos.html
