944S Exhaust Cam Needed
I'm considering building one myself.
In PCA, SP3 class, 188 bhp (+ whatever the new allowable mods are worth) and a 2500lb weight with driver vs. the 944T (86-88 non S) at 2875, the S2 at 2750 or the 944TS at 3050.
Michael - will answer you via PM once I have a look at my parts stash.
T
I need the 'S' exhaust cam for a stock class engine. I have S2 cams, and can trade two for one if that helps. The 'S' exhaust cams are stamped 275.04 usually on the back end of the camshaft, but sometimes along the shaft on a machined pad. The critical numbers are stamped, not cast in the camshaft.
Who has one of these??
Michael, have you tried George B at 944 Ecology?
Michael,
I believe I have what your looking for, the camshafts look great.
Also we have the lifters numbered with there location.
I will send you pictures tomorrow.
Max
Max
All I have is one with two broken teeth.
Bought an 87 S in 1990, cars still pretty new, popped timing belt, engine in boxes. Would have passed but the car was low mileage and clean as a pin.
Two used cams cost me $750 each back then.
T
