968 M0303 big blacks for 86 951
Found some 968 M030 big black calipers for sale. What would I need to mount those to my 86 951? The guy is also selling matching 968 spindles with rotors. My car btw was not a M030 package car
Basic Sponsor
http://www.ebay.com/itm/Porsche-86-9...e=STRK:MESE:IT
The spindles he has are for $180... Comes with hubs, dust caps, steering knuckles, and speed sensors. The rotors are cross drilled. The big blacks are $550. Sounds like it's a good deal? So would swapping out the spindles be ok? I know the 968 is the late offset while mine is early. Does that make a big deal?
Basic Sponsor
Did the 968 come with Big Blacks or Medium Blacks?
Basic Sponsor
968 m030 calipers are NOT "big blacks", they are the same as the 928 S4. The 928 GTS are the "big black" calipers which you can run with the 968 m030 spindle if you also run 928 GTS or 964 turbo rotors.
Rich
Rich
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
M030 is ok...
but, adaptors to make the Big Blacks fit the regular 968 spindles are available at Paragon,
then, Koni inserts, bigger sway bars, etc....
As Lart stated, if you can get matching 968 m030 spindles and hubs, jump on it. It's a no brainer. Those brakes are plenty for most applications. The spindles also will allow you to directly bolt on big blacks, which are 928 gts calipers as stated. Standard 968 m030 are s4's as stated as well. In other words, I didn't add much
