So after replacing my vacuum lines (including venturi delete) it won't run
#46
Well, at least I've narrowed down some of them. I know the vacuum system is good since I just checked it, I physically inspected the turbo and it seemed in good shape and spun freely by hand, I checked the wastegate and it was closed (not stuck open) and tried the "clamp the wastegate hose" trick and it didn't seem to change anything. I had read about the collapsed pipes, I guess I'll need to drop the exhaust next. It has an exhaust leak from where the exhaust manifold meets the downpipes and it leaks pretty bad ( a lot of smoke under the hood) if you rev it. I wonder if that points towards a collapsed down pipe. It also doesn't like to rev much.
Drove it to work, just because I wanted to drive it at least once before tearing it apart again. Even as it is I really enjoyed it!
#47
If you clamped the wastegate line you should have over boosted. Since you checked the turbo, I'd say the cat or down pipe is collapsed. Take the pipe off after the down pipe and look up in there. The pipe bends so you may need a mirror or an accommodating tool to see completely inside. If that's clear give it a test run with the cat back off. If it boosts, you need a cat or need to hollow yours lol.
#48
#50
I'll try plugging it as a test to rule that out as well. Thanks for the tips, I'll have a number of things to try out tonight. I'm leaning towards some part of the exhaust. I hope it's the cat as that would be a reason to upgrade the exhaust, which would be less expensive (and easier) than replacing the turbo/downpipe. I know I can keep it stock, but it -would- be tempting to do something while I was in there.
Drove it out and got my temp tags. Even popped the roof out and enjoyed a rare (normally) hot and sunny afternoon in Colorado in November!
