Wossner custom 3.0 pistons.
Which machine shops have you approached?
I contacted Capricorn regarding their Alloy Nickel Ceramic liners & they recommended Geoff Page Racing who apparently has done a number of these installation on 951s.
Wossner's European distribution seems to be virtually non-existent - there's no UK dealer & you don't seem to be able to order direct from Germany.
Tim
Tim
I've contacted them 2 or 3 times in the past and never got a reply.
Tim
Tim
I emailed Geoff Page ages ago but never got a reply. I've had my build on hold as other demands on my finances have pushed it well down my list of priorities.
I don't know if Geoff Page will be very cost effective as I get the impression he does a lot of high-end stuff for very wealthy collectors/competitors - but that's just an assumption.
Gantspeed were very welcoming & given their work on Cherburator's racing 928 they would be well up to the task.
I've accumulated all my own parts so JMG would not be an option for me - plus the few times I've tried ordering anything from them - I had to continually chase as no one ever called back & I gave up in the end!
I will see what the Wössner factory says. Last time I checked custom 944 pistons were actually cheaper via US but things might have changed now with the stronger USD exchange rate.
Rainman
Maybe you should take a trip out here, buy a suitcase on landing and fill it with engine parts to take back as a carry-on
I heard of a block where the liners didn't have cutouts for the windage ports and was told the machine shop wanted $$$$$ to machine the cutouts in afterwards.
I paid 1500£ including vat.
He also told me that grinding down the windage ports where a real PITA because the ductile iron is extremely hard.
When I asked Capricorn a 2 or 3 years back I think they said £1800 for installed plated liners, if they still do it I'd probably use them. I believe they correctly space the bores, make sure they line up properly with the crank and machine the girdle if necessary. If I recall correctly Serdi said around £500 to bore and refinish the Alusil cylinders.
Even at £2K I think the Capricorn approach would be the best - provided they use an ALLOY Nickel Ceramic liner rather than steel.
I can see steel being fine for a dedicated trackday or racing car where it will be carefully warmed-up before being run very hot for extended periods.
For a dual purpose car - I think the reduced expansion differential of alloy liners is the answer given frequent hot & cold starts, short trips, reduced warm-up time etc.
I'm sceptical of finding someone in the UK who can do a really good job of Alusil honing. While it shouldn't be rocket science I think it's done so infrequently here now that much of the skill & experience has been lost.
Tim
Tim
Tim
Tim
From their website: capricorn AUTOMOTIVE Ltd. offers high-performance wet or dry nickel-ceramic-plated cylinder liners to the motor racing and niche OEM industry
I don't know how hard can it be to just follow the instructions for Alusil boring and lapping from 944 service manual. There is an exact procedure there, step by step and here are even new solutions covered in detail.. http://download.ms-motorservice.com/...947-02_web.pdf
Every machine shop thinks they are smarter than anything and just do it their own way which usually ends with ruined block.
I have second one in the shop, they said it would be done by last friday and still nothing. I hope I wont need to search for third 104mm block.
I know Capricorn used to fit alloy dry liners, someone that lives near me had one fitted quite a long time ago. I think Capricorn is quite a big outfit now, wasn't it them that tried to take over the Nurburgring recently ? Shame there aren't any new 968 blocks around now.
When I asked here about the windage cutouts in the liners the advice was to cut them before installing the liner, a lot easier than trying to do it in situ I'd have thought.
