951 Motor with V8-style bell housing?
Anyone ever see a 951/944 motor mated to a traditional transmission and rear axle -- e.g. a Muncie 4-speed and Ford rear axle? Curious if anyone has adapted a bell housing, etc. for this purpose?
Almost certain that black car out of Sweden 3-5 year ago with the Audi i5 motor mated it to a Supra gearbox Tom. There's a thread in here about it somewhere. I'll have a look for it.
http://www.eurotuner.com/featuredveh...o_session.html
That's the car. There was a quite a comprehensive thread in here about it with quite a few pics. I remember Special Tool kind of rubbished it which I thought was unwarranted. Looked a great project to me.
Why are you researching this Tom?
My projects tend to start as a daydream, then take hold in fits and starts over many years -- but eventually I usually get to them...
I've been thinking of getting an old smog-exempt mini pick-up for some time -- like a Toyota hilux for example. I figured if they could stuff a small block in there.....
Rainman
It might be more straightforward to adapt the 951 bellhousing to a conventional transmission.
The Porsche 944 1"x23 clutch is used on 3.0/4.0 V6 manual trans Ford trucks. It is also used on the current Mustang GT 5.0, as well as old Mopars and the RX8.
Or the Ford/Mazda M5OD trans might fit the 951 block with an adapter plate/clutch setup, it uses that 1"x23 pattern with an integral BH and I believe has the same pilot bearing size.
As for other trannies, it does seem like an adapter plate could allow something close to mate up...
