INTAKES: What do you run or are building?
Old 08-07-2014, 09:23 PM
  #151
V2Rocket
Rainman
V2Rocket's Avatar
runner length seemed to be important...
Old 08-07-2014, 09:40 PM
  #152
refresh951
refresh951's Avatar
It is all in the details. This motor was a 2.5L with a relatively small turbo. The motor produced 410 bhp. The long runner provides dynamic charging on the order of 2-4 psi in the mid range which the GPT motor obviously benefited from.
The short runner, large plenum intake really only sometimes makes sense on a bigger motor with a large efficient turbo capable of delivering plenty of boost in the mid range and then benefiting from higher VE after 6000 rpm due to the shorter runner. It really makes sense on a motor with a higher than 6500 redline.
Old 09-01-2014, 10:21 AM
  #153
Dutch944
Dutch944's Avatar
So, this is mine:
Old 09-01-2014, 10:25 AM
  #154
refresh951
refresh951's Avatar
Very nice Bas! Runner length? Plenum volume?
Old 09-01-2014, 11:21 AM
  #155
Dutch944
Dutch944's Avatar
Still have to measure and calculate! Will do that on wednesday i think.. Have a lot going on apart from the car-works.
Old 09-01-2014, 02:02 PM
  #156
tkgb
tkgb's Avatar
Im working on a new intake for a 2.7 liter 8 valve head.
All the parts are cnc-milled out of aluminiumbillets except the runners.
I have not really decided how the lid of the plenum going to look yet but im working on it
Tommy
Old 09-01-2014, 02:10 PM
  #157
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Nice job! Very clean welds.
Old 09-01-2014, 02:38 PM
  #158
Dutch944
Dutch944's Avatar
Nice job, but why the straight shape of the intake? You can get much better results with a v-shape!
Old 09-01-2014, 03:52 PM
  #159
tkgb
tkgb's Avatar
Your intake look really good and will probably work very well.
Yes the shape is straight but there will be one more part welded on later.
I have not decided if im going to feed the air between cylinder 2 an 3 or at the front like on your intake?
On my old intake i feed the air between cylinder 2 and 3 and it seems to work.
This engine made 481 RWHP on the dyno.
Old 09-02-2014, 04:15 AM
  #160
Dutch944
Dutch944's Avatar
I would always enter from the from, you get much better similar airflow on all cilinders!
I would really advice to get the extra part welded on, similar to mine!
Old 12-07-2014, 04:01 PM
  #161
tkgb
tkgb's Avatar
Made some progress this weekend and milled out the second part of the plenum.
Some welding left to do but most of the work is done now
tommy
Old 12-07-2014, 06:10 PM
  #162
refresh951
refresh951's Avatar
nice!
Old 12-07-2014, 06:20 PM
  #163
Voith
Voith's Avatar
Wow, what a beauty.
Old 12-07-2014, 07:24 PM
  #164
tkgb
tkgb's Avatar
I hope it will work ok.
The 65 mm throttlebody is from a Volvo 960 so there is at least one swedish qualitypart on the engine
Old 12-07-2014, 09:20 PM
  #165
gruhsy
gruhsy's Avatar
Very nice
Originally Posted by tkgb
Quick Reply: INTAKES: What do you run or are building?
