New race car - 968
Love it ....
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
there are lots of gear options for the 968 transmission. parts source; Scott Dewitt/Advanced Automotion, Corpus Christi, TX
Roger Brown @ California Motorsports, Lake Havasu, AZ
stock 968 ratios;
1st; 3.182 :1
2nd; 2.000 :1
3rd; 1.435 :1
4th; 1.111 :1
5th; 0.912 :1
6th. 0.778 :1
final ratio 3.778 w/ open diff.
short ratios; [available @California Motorsports]
1st; 3.182 :1
2nd; 2.000 :1
3rd; 1.526: 1
4th; 1.227 :1
5th; 1.042 :1
6th. 0.893 :1
tall gears for high hp engines.
1st; 3.182 :1
2nd; 2.000 :1
3rd; 1.230 :1
4th; 0.930: 1
5th; 0.729 :1
6th. 0.600 :1
oem 968 Turbo S 6 speed [complete boxes almost impossible to find]:
1st; 3.182 :1
2nd; 2.000 :1
3rd; 1.435 :1
4th; 1.111 :1
5th; 0.882 :1 [very limited availability]
6th; 0.711 :1 [very limited availability]
final ratio; 3.455 w/ limited slip diff. [very limited availability]
the gears from the euro 2wd A4 diesels fit the 968 box
as long as the gear #s match.
4th with 4th, 5th with 5th, etc...
list of available gearsets 3~6 from the Euro A4 Diesels
1.32 1.07 0.86 0.73
1.23 0.93 0.73 0.60
.......0.87 0.67 0.56
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Great information there, Thanks for sharing.
What is the preferred method to turn a non-LSD 968 6-Speed into a LSD unit? I assume the LSD from a 951 will not swap right in.
Mine, FWIW, is a Torsen, which is not that normal, given that it is aftermarket. The gearing is the same 1-6, but the R&P is a bit shorter. I think Clark said 4.11. MUCH shorter. I'll be pulling a good bit less from 60-66, a LOT harder from to 83, a little less until 95, a good bit more until 107, and then the curves sit on top of each other.
Yep. Clark had about that much in this one with the custom gearing stuff. And that was 10 years ago!!! Seriously, give Karl a call. He's put those Elite diffs in a few of these cars, one he set a few records in before he sold it last year.
I really like my OS Giken LSD in my tall ratio 968 'box. Feels great, smoother than the stock ZF LSD.
Worked last weekend on installing some 993 headlight conversion on someone's 968, have to check who made the fenders but I don't think it was D9 units, about which I heard they really were not great.
