Rear hatch releasing @ track
Wasn't sure last season...I'm sure now!
The rear hatch (left side) releases during a moderate speed right hand turn at Tremblant (turn 8)
Anyone have a solution?
thanks
thanks
What about re-aligning the hatch pins. I did it to my car when the hatch wouldn't latch anymore on one side.
I loosened the catches on the inside, then I got in the trunk and closed the hatch with everything loose. Then tighten it up and test it.
If that fails use the red green solution: duct tape
Put these in and adjust pins.
http://only944.com/partscatalog/only/hatchpinseats/
You do need to check for pin wear. If they are shot, put these in.
http://rennbay.com/944-Hatch-Pins-Stainless.html
Mine was doing that too (releasing). See my notes below - hatch is tight as a vault now...
https://rennlist.com/forums/924-931-...plemental.html
