Timing belt slipped bent valves.
Hey Paulyy
That really sucks
Very sorry bud .... I hope it all works out, and there is not too much damage
Regards
Ed
That really sucks
Regards
Ed
Professional Hoon
Alek: The result of the tensioner not being tight after starting the car after tightening the crank bolt
Eric: yep CEP Head. dave's looking at some valves for me.
Lart: Yep i do all my work. I didn't do the head though. CEP. still young, still learning.
Sid: haha! I'm not game enough to start porting the head. it's been ported by dave @ CEP. the head and cam have been matched to eachother.
Cheers guys for the love. I'll probably take my time with this one. just because of work. car is rarely driven these days. just weekend. average 200miles a week if i'm lucky.
I'll keep this thread updated.
ATM i'll probably need a gasket kit. valves and guides.
What a bummer Paul
Was indeed the crank bolt loose? Why did you have to loosen the tensioner to tighten the crank bolt?
When ever I do something on my car I have this procedure before I start it where I stand in front of the car and look at everything I have done thinking of any potential things left undone. I am amazed how many times this has saved me from disaster. Hope you get it fixed soon mate.
Professional Hoon
Correct. that was the start of the issue.
I had to loosen all the belts to get the crank shaft pulley on properly or would just not sit 100% flat.
I'll have to take note of your procedure. I do the same though. But sometimes you miss something.
I'll be giving this a few months and take my sweet time with this. it's winter and i've got work, so it'll be an after work thing.
Because the car is in my garage and not at my shop, it makes things a little harder.
During the week i'll get the head off. tomorrow i'll get the cam tower off.
Do you believe i can remove the head with out unbolting the exhaust manifold from the head, just the crossover? or is it possible to recuse gaskets?
I'll keep this as my primary thread. if i do updates on my car, it'll go to the build thread.
What a bummer Paul
Professional Hoon
This gives me a chance to clean things up again. I've had coolant leaking from the rubber hose that connects to the top of the head and coolant has collected between the head and block. I've had some coolant leak under pressure from another hose that i can now clean up.
Sorry to hear this. but sounds like u got it under control. At what point is an upgraded head needed? Who's the best for this lr have some flow numbers on there's can't find much less. What's the deal with use n/a head or valves? Under stand there larger but you lose the ceramic exhaust ports
1 Post
Larger valves will move the curve to the left aka loss of tq . The ceramic coating will keep heat / velocity = less lag.
Pro head porting is a art plus you need a upgraded valve train / cam to take advantage of it. Done right = expensive
gotta triple check when it comes to stuff like that.
Why was your crank pulley loose in the 1st place?
I would toss that auto tensioner and convert to manual. That is what i did.
Professional Hoon
We just don't know why it was loose. When it was put together, it was torqued to spec.
with the auto tensioner, I'll just put pressure on it before tensioning it next time. I really don't want to be fiddling around with that.
