Lindsey vacuum hose kit?
I called again today and talked to Dave, first time I've dealt with them and great customer service!! Just like everyone said.
Anyway, he's got the hoses for the idle stabilizer as well as for the brake booster, my order hadn't been picked up yet so he just added them in.
Thanks Dave!
Sam
Thanks Dave!
Sam
the lindsey hoses are awesome, good quality silicone hoses, enough fittings, etc. i would also recommend instead of re-running a lot of the factory lines, take this opportunity to eliminate the cycling-valve. also, get a crank-case breather (iirc, the whole point is, plumbing this stuff back into the intake tract means introducing oil vapor into the combustion chambers thus reducing the effective octane rating of your gas, and increasing the effective compression ratio due to volume occupied by oil vapor). also get the updated brake booster hose. these things won't cost you an arm and a leg, but will (imo) improve reliability, and i'm a big fan of simplifying when/where possible on these cars.
heck, i currently have all of 4 vac. lines - manifold->T->fpr(2nd line go another T->DV+fuel rail damper. ok, i lied, 6 lines- one more T that goes to my boost gauge, and the factory KLR hardline
Just installed the Lindsey kit yesterday. Excellent quality on the hose and fittings. It felt great to sort out a little if the vac line mess the exsists under the manifold. This was one area where it is nice to improve on design.
Thanks Sam. I completed the swap last week. The old engine had 185K, and needed front/rear seals, oil pan gasket, head job, bearings, etc. I figured it would be easier to swap it out with a fresh engine, so 6 working days later, the beast had a new heart. It wasn't as bad as I first thought it would be. Maybe I should start a new thread with my progress pics.
Can anyone post of email me that diagram of vacuum line routing? I've been battling low boost for a couple of months now and would like to verify correct routing on my car...
I was just reading this in the archives and would like to ask a stupid question:
Can I replace the small vacuum lines with the $30 lindsey kit without removing the intake manifold? I realize that this means that I'll leave the large hoses untouched, but I figure that the small hoses would be a good start / preventative measure.
As further background, I have a reliaboost and can simply bypass the cycling valve (in fact, this seems to be Danno's suggested approach nowadays)
1 Post
I just bought a 951, and looking down into the engine compartment depresses me. What's all that stuff down there? My NA was much simpler. Is there like a picture of the enginebay with arrows and descriptions of the different thingys? Where is this cycling valve everyone keeps talking about?
$30? I'd love to do this too, but have NO idea where to start.
The kit is indeed on lindseyracing.com. There are actually two kits, one is about $30 and replaces all of the thin plastic hoses that run around the engine compartment into little rubber connectors. This is the one that I was asking about. The other is about $60 and includes a few large hoses that live under the intake manifold. There's no way to change these without taking off the intake manifold, which, from Clark's Garage's instructions, looks pretty involved. Most people who have replaced these hoses claim that they are in terrible shape, so this is certainly worth doing if you are willing to go through the effort or have to have the manifold off anyway. I figure that I'll start with the simple approach and see how things pan out.
schnellfahrer, start searching the archives. I was in your position three months ago, and have picked up quite a bit from old posts.
KLR, don't bother, do the big kit while you're in there. Intake manifold, other than requiring 4 new gaskets at about 1.60 each, takes 10 minutes to remove.
Sam
Sam
