Plastex Plastic Repair Kit
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
I have posted about this on FB, but since some have given up on that site I might as well post it here as well. This is more of a testimonial on a product that worked as advertised. I needed to repair a broken tab on my 3-Spoke Tiptronic wheel. The tab was completely missing when the wheel arrived. The replacement switch which contains some embedded sensors is nearly $700 from Sunset. That was a no go, so I used this stuff I bought at SEMA a long time ago. I must say it worked perfectly and I am sure many of you would have a use for this kit. It includes a reusable "mold" that gets very soft when boiled in water and then hardens up at room temp. Please see pics below:
![Name: image-138662024.jpg
Size: 412.7 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/816736d1395261150-plastex-plastic-repair-kit-image-138662024.jpg)
Above picture shows broken tab that holds rocker switch in place.
![Name: image-580168710.jpg
Size: 410.2 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/816737d1395261345-plastex-plastic-repair-kit-image-580168710.jpg)
Above picture shows good switch on opposite side which I used to make a mold from.
![Name: image-3554540592.jpg
Size: 449.8 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/816739d1395261418-plastex-plastic-repair-kit-image-3554540592.jpg)
Aforementioned mold is above.
![Name: image-2470456351.jpg
Size: 393.7 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/816740d1395261447-plastex-plastic-repair-kit-image-2470456351.jpg)
Mold in place
![Name: image-148444120.jpg
Size: 481.1 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/816741d1395261465-plastex-plastic-repair-kit-image-148444120.jpg)
Repaired piece
![Name: image-2680073875.jpg
Size: 481.0 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/816742d1395261486-plastex-plastic-repair-kit-image-2680073875.jpg)
Another shot of repaired piece after some fine tuning with Dremel tool and small file.
![Name: image-3071522102.jpg
Size: 362.0 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/816743d1395261537-plastex-plastic-repair-kit-image-3071522102.jpg)
Rocker switch fitted.
Mold in place
Repaired piece
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Looks like great stuff and easy to work with if your not all thumbs. Question is just where can one buy this same kit? I'd like to have a kit on hand just because.
Answered my question.
http://www.google.com/aclk?sa=L&ai=C...y=19&clkt=1359
Cheers,
Larry
Cheers,
Larry
1 Post
Managed to knock out the machine work on the end mill last night, came out pretty nice. Hope to have it mounted this weekend.
![Name: image-3623485841.jpg
Size: 405.6 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/817342d1395422474-plastex-plastic-repair-kit-image-3623485841.jpg)
Part for connection to stereo has yet to arrive, going to install it first without this functionality.
What head unit are you using? I recently did a similar installation on my E32 740i but with a Kenwood receiver, which allowed me to hard wire the connection from the adapter to the receiver.
It's much more responsive/reliable than the IR solution I have with my Blaupunkt receiver, I suspect I'll be swapping it out for something else here soon in the 951.
1 Post
I have the latest and greatest Alpine, CDE-149BT. I have no idea if it has the Kenwood feature you are referring too. I will have to ask my car audio guy. That would be nice if it did. I know the BT operation from IPhone works great.
I think you'll be good to go with the Alpine deck. Most decks these day have a hard wired rempote option, my Blau just has an external IR "eyeball" that's not as responsive as I'd like.
1 Post
I think this is the little gem that I need to complete this project.
![Name: image-3759604075.jpg
Size: 385.9 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/817442d1395437942-plastex-plastic-repair-kit-image-3759604075.jpg)
Sounds like the right one and I have the correct RCA Jack in the back of my HU.
