Request picture of water necks on turbo head.
I got mine powder coated to cover some corrosion and as a result I have mixed up some bolts and hardware. I can't remember how this should look. Are they allen head bolts? Is there a bracket on any of these water necks?
Pictures would help me know what I should look for in all the small bags and pots I have sitting around.
2- Mounted
1- Disassembled
WATER NECK two parts and components
-(4) M8 X 30 WITH WASHERS
-(1) BLEED SCREW WITH WASHER
and 2 GASKETS
Hope that helps
Ed
ps BTW
I believe that those screws are not just your run-of-the mill Allen heads? The heads of those specific screws, may have shorter heads, so there could be a clearance issue using standard screws, with the water neck. My friend Tom, told me he had some issues with screws he bought from a Porsche dealer ( i.e. replacement screws )
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The bottom two bolts are the critical ones - they need to be the 'thin head' type shown in the pictures, the upper two just have to be the right length.
Is that a champagne cork in the turbo drain hole? now that's creative!
They wont shine as much but yeah. These are factory bolts.
I've never been clear on the part number for the thin head bolts, and it seems clear many cars came with normal head-thickness bolts for some reason. I may be the casting of the neck changed over the years, but I don't know that for sure. I punted and just ground a little off a regular allen head bolt. See thread here:
https://rennlist.com/forums/944-turb...leak-jinx.html
