Balance Shafts Revisited
Does anyone know what's inside the black plastic covers on the balance shaft? Are they solid or hollow?
I'm thinking about using a lathe to remove a certain amount of weight from the balance shaft to counter the weight I'm removing from the reciprocating assembly. Since the covers make the whole thing round it's going to cut into the plastic cover too.
Old shafts have no plastic, that would probably make it a better candidate for removing material. Plastic can fall off and cause hole in the block.
![](http://img.photobucket.com/albums/v492/madrob6/Porsche%20944/IMG00249-20110402-1500.jpg)
If you put lighter pistons and rods in an engine, balance shafts will put out more vibrating energy than reciprocating mass. Thus creating secondary vibration that were designed to cancel.
In theory.
In theory.
Do you know how to calculate revised imbalance, and subsequently the revised balance shaft requirement? I don't, and I wouldn't mess with it unless I knew how to calculate it. I think you are asking for more trouble than it is worth. Keep in mind, it isn't grams you are using, it is gram-mm's (or ounce-inches), as inertia is what is critical, not mass.
FWIW, if you do a search for parts, you'll see that the 968, S2, Turbo, NA, and S all use the same balance shaft - only the 2.7L uses a different one. I'd expect that the differences between all of the ones using the same shafts are probably greater than your deviation from stock.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I can offer a semi scientific method for 'adjusting' the balance shafts - figure out the reciprocating weight (piston, rings, pins and little end of the rods) of the stock set up and the set up you are using. Calculate the percentage difference and then cut off that percentage of the length of the counter weighted part of the balance shaft. If you get hear the mounting point of the plastic you will have a problem with it staying in place. The plastic is just an aerodynamic aid - remember that he balance shafts are spinning at twice the speed of the crank....up to 13,000 rpm
Thanks for all the input. Yes I looked at a formula that calculates the imbalance and it's complex since the weights distance from center matters.
I already weighed the new pistons and rods. The new reciprocating assembly is 124 grams lighter per cylinder. That's a big difference, I don't feel comfortable keeping the stock shafts intact.
For comparison the weight of piston/rods from a stock 951 is 3 lb- 10 ounces
My new piston/rod combo is 2lb-11 ounces
Just for comparison a Mitsubishi DSM 1990-1992 6 bolt piston/rod is 2lb- 13 ounces
Stock Mitsubishi 2003-2006 EVO piston/rod is 2lb- 9 ounces.
The fact that Porsche used the same shafts in a few different engines tells me that the actual balance shaft weight might not matter to a high degree. I'm not looking for a perfect solution, but is there something better? Maybe the motor mounts in these cars are good enough to make up the difference?
Oh yeah, I looked at it as a percentage as well. Since I'm building a 2.8 stroker,
stroke increase 8.86%
weight decrease 15.53%
total difference in 'balance weight' 6.87%
OK now what?
How do I measure the imbalance in the shafts?
EDIT; I just noticed Chris said to cut off from the length of the weight. Good idea! I was thinking of using a lathe and reducing the radius which is obviously complicated since it removes weight and radius.
OK now what?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I messed with this some a while back and ended up aligning both shafts one tooth off in opposing directions and it made a difference. I had a thread on it IIRC.
I like that idea! But it still raises the question, if the plastic covers are hollow then I don't want to cut through the outer shell. If oil gets inside it'll throw off the balance again.
Interesting idea, I'll have to check out that thread.
OK now what?
OK now what?
The contribution from each of the balance shafts is additive, so the lengths of the counterweights on each shaft should be reduced by only 3.33%.
Here is another thread on the subject:
https://rennlist.com/forums/944-turb...ft-belt-3.html
Laust
