Plugging the fuel vapor purge line
I've got a question concerning the fuel vapor purge system. I'm not running a factory BOV or an ISV so in the interest of easing fabrication of my air intake pipe and saving weight, I'd like to also delete the connection for the fuel vapor purge and vent that to atmosphere. Can I leave all the equipment in place temporarily and just plug the line that would have gone into the J boot, and then throw on a vented gas cap? I would be gutting the system entirely eventually.
You can put a cap on the J boot fitting, but leave the vent hose open. This is the path that allows expansion/ contraction of fuel vapors in the fuel tank due to temperature changes.
I actually wont be running a J boot in the traditional sense, just a pipe with a single bung for the AOS straight into the turbo inlet. I just wasnt sure if it was ok to simply leave the fuel vapor purge line uncapped and open. Should I just tuck it back by the firewall, or tuck it down to vent into the driver side fender well?
Does anybody know the ID of the AOS to j boot hose so I can weld a bung on?
I capped and deleted everything. The only thing i vented was the tube that comes out of the gas tank that goes to the front of car. I put one of those cheap vent filters from autozone by the T-Bars. Never smelled any gas since.
Drilling your gas cap is dangerous......
Thanks Scott, I'll probably vent the tank by the TBs and leave all the equipment in place under the hood for the very immediate time being. I kind of assumed it was that simple.
So you really think that fuel is going to come gushing out of a 3/32" hole in a gas cap if the car is inverted.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
