Question about '86 Wheel Fitment
Have been doing some searching but would also like to ask the gurus about these wheels fitting on a 1986 951:
Fikses
18x8 +51 offset fronts
18x10.5 +57 offset rears
Thanks in advance!
Jase.
Fikses
Thanks in advance!
Jase.
Fikse are good wheels. Assuming you have stock suspension set up- fronts will be fine up to 235mm tires- stay with 225mm to be safe as the front fenders are not rolled from the factory. Rears won't fit without some fender lips rolling at the minimum if not running a couple degrees of negative camber. Here's why: You will need early offset wheels as 86 have 23mm ET. So with 57mm you are roughly pushing the inner edge of the wheels more than an inch inwards (57 - 23.2) running into nuts and bolts back there. To combat this, you need spacer at least 25mm to push it back out to wards the outside fender lips. Coupled with running pretty wide 10.5 in. wheels, you will rub onto the lips at full compression since they don't come rolled from the factory like the S models. Running this wide of wheels in the rear, there is no point not using at least 285-295mm tires. And using these tires will add to the rubbing issues on the outside. Running 265mm will help a lot but then again, it will look out of place unless you are into the stretched look then you have to run 205mm in the front to match the look. At that point why bother running wider wheels in the first place and use skinny tires??? Ymmv as different suspension set up, lowering height, choosing tire manufacturers and your usage of the car are all factors in determining if you could run this set of wheels. Good luck.
Fikse are good wheels. Assuming you have stock suspension set up- fronts will be fine up to 235mm tires- stay with 225mm to be safe as the front fenders are not rolled from the factory. Rears won't fit without some fender lips rolling at the minimum if not running a couple degrees of negative camber. Here's why: You will need early offset wheels as 86 have 23mm ET. So with 57mm you are roughly pushing the inner edge of the wheels more than an inch inwards (57 - 23.2) running into nuts and bolts back there. To combat this, you need spacer at least 25mm to push it back out to wards the outside fender lips. Coupled with running pretty wide 10.5 in. wheels, you will rub onto the lips at full compression since, they don't come rolled from the factory like the S models. Running this wide of wheels in the rear, there is no point not using at least 285-295mm tires. And using these tires will add to the rubbing issues on the outside. Running 265mm will help a lot but then again, it will look out of place unless you are into the stretched look then you have to run 205mm in the front to match the look. At that point why bother running wider wheels in the first place and use skinny tires??? Ymmv as different suspension set up, lowering height, choosing tire manufacturers and your usage of the car are all factors in determining if you could run this set of wheels. Good luck.
That is not true, 25mm spacers would push the lip of the wheel out 23mm past where the stock wheel lip sits.
Hey guys,
Thanks for the replies! The tires I was thinking of running would be 245 front and 295 rear... My suspension is still stock atm, but there are lots of things on the car that I want to mod, so I wouldn't be spending just to get the wheels to fit! Thanks again for the info
Jase.
Jase.
Good point. I was thinking of getting the off set back close to stock ET. You didn't mention what tires you are running- anything less than 285mm on the OP 10.5" is less than ideal imo and you are asking him to run stiffer all around as well as lowered ( you have to if you running stiffer springs) so that's a lot of work and $$$ just to run the wheels. From the look of the car and the OP didn't mention anything about wanting to mod the suspension, I don't think spacers alone will work.
They sound like they are built for a late offset car.
If you're going to get 3-piece wheels, why not get ones in the right offset?
I'm not a fan of using adapters anyway.
Also, that size is very aggressive even if the offset was spot on. 8" fronts may rub on the strut perches/springs. 10.5" rears could rub either in the inside well or the outer lip.
Take care,
Take care,
I'm running 245/40-18 and285/30-18. No problem with rear fenders. Get perfect adapters made for rear. Fronts rubbed strut slightly. 7 mm spacer did trick.
86 with Konis
10.5 rear wheel, 55 offset
86 with Konis
I was thinking of changing my decision to 285s for the rear since they were 10.5" and just to work things into my favor. I appreciate the info!
I just picked up the wheels yesterday, should look sweet!
Jase
Take care,
Take care,
Jase.
