Surprising
Today I got a little bored and Started tinkering with the 951, I've got the boost itch so I've been looking at ways to make more power without spending a ton, I have the 951Max chip installed, the PO had a autothority chip installed when the car was stock that I swapped out when I did the 26/8 turbo, 3" exhaust and dual port waste gate, I've been running 15-16psi, and Im starting to get a little lean 12.1 to 12.3 at full boost, So today for fun I swapped the old Autothority chips in, And
I don't know if Im crazy, but the exhaust note sounds different, my A/F ratio is now 10.5 ish at full boost and the car seems to be running better and pulling better, I even turned up the boost to 17psi.... Does this sound crazy or can chips change that much from make to make?
It's stock fuel system with a 3bar regulator, I know I was running out of fuel with the 951max chips, and eventually I'll go with a m-tune and bigger injectors, but for now I almost want to keep the autothority chips in (they are from 1995) lol, I fell better with a 10.5-11 A/F then I do with the 12-12.6, what's a good ratio to have under boost?
At WOT you want to be around 11.5-12.
At 10.5 you are leaving a lot of power on the table.
Basic Sponsor
10.5 is a bit rich, remember that the oppositte damage of a lean condition would be too rich, that would cause your cyl walls to be washed with extra fuel, increasing the possibility of cyl scoring
Basic Sponsor
