Throttle Body Options?
#46
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Shawn, what is considered a low price? Is the BMW a direct fit? Which model unit are they using? If I could get a direct fit upgrade under $300 I would be happy. I wish I still had the specs on my HR unit. I can't find them on the net anymore. It might not be much more than stock. It is over in OK so I can't measure it. I am pretty sure that one was $200-300 back in 2000 so not cheap. It did come with a yellow HR sticker on the TB plate, so had to be worth it! Ha!
#51
I run a 75mm TB on a 2.3L turbo charged engine with a 63mm FMIC compressor side and 75mm intake side, ported intake to match head and it all works fantastic on the street.
#52
Got the Mustang 65 mm TB mounted today. Everything fits with the 951 pulley screwed to the TB. Just clears the turbo water pump with no modification. I plan to to test drive it tomorrow.
![](http://www.refresh951.com/MTBmount.jpg)
#55
Hey Shawn. Did I miss something? there is a vac port behind the throttle body in your pic.
#58
Some of the early TBs were slightly different to the later ones as featuring a "solid" throttle cam as shown here, with a shiny rough aluminium finish and a gold (zinc-plated) throttle blade.
#59
From my extensive eBay research, it looks like those throttle cams may have been used on the 944S throttle body, which otherwise looks the same as a 951...
