Throttle Body Options?
What are the best bigger throttle body options out there these days? I've used the 928S unit, but have never been happy with the linkage, which creates short pedal travel. Boring the 951 unit doesn't get you very far...
So...who has a good (good and big) throttle body option?
I did talk to Chris about this, I believe his option is only for a stand alone as they will not work with the stock TPS.
As long as it has a TPS of some kind, we can scale the pot and simulate a closed idle contact if needed. We could probably do it with a few components without the need for a microprocessor really...(since it's no fun to wait for your throttle body to boot up)...
Doesn't seem to be too much evidence from people that have used larger T/Bodies on these cars. There also seems to be quite varied opinions regarding just how much bigger to run before it really affects driveability. Pretty sure the one we're running on the racemotor is 66mm. That seems to be a decent % larger than stock without losing smoothness...I hope.
I'm sure Sean/JET951 is looking to use the Audi one pictured above on his new Intake. He might chime in with further details.
Well.. I'm interested as well! I've also been looking for actuator controller throttle body's. You can use the stock 951 pedaltravel length but use a way bigger throttle body instead. Also handy to use for traction control or launch control..
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
