Mobil 1 0w-40?
Don't think my oil pressure dropped below ~3.5 bar on the track today, running Mobil 1 synthetic 15w50 and STP oil filter( same as OEM I've been told ) and factory oil cooler.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
I use the synthetic but think you will also be fine with VR1 conventional if you change every 3000 miles on a street car. There is nothing wrong with the stock filter, but there will soon be better filter options, stay tuned. Quite a bit has changed in filters during the last 5 years.
Best to have your oil tested to find out a little bit what is going on with your engine. Of course you will need to do this several times after each change.
So really it just comes down to choosing which brand you have the most faith in?
Valvoline VR-1, Mobil 1 Synthetic, etc?
What is the best brand of oil, weight, and type (conventional/synthetic) for street use in your opinion?
Professional Hoon
Oh man not another oil thread.
If you live in a normal temperature area. Like from 0°c - 40c... 20w-50 is the oil you want
I use semi synthetic. i wouldn't use synthetic as it'll strip the minerals from the bearings and may cause damage. And if you have small leaks with normal oil, the synthetic oil will turn them into larger leaks.
I think that Millers product sounds pretty good. Having said that, "If it ain't broke, don't fix it comes to mind".
Seems like a lot of differing opinions on synthetic or conventional?
FYI this 86 turbo was just rebuilt with new seals, bearings, water pump, etc. if that makes any difference!
Yes lots of opinions.
Some good information here: http://www.bobistheoilguy.com/
I've also witnessed a couple different presentations on oils from Charles Navarro of LN Engineering, he's done a ton of research on oils used in racing engines. I've been running whatever he recommends.
For filters I would go with Mahle Filters. The 944 filter has a check valve in it to keep the oil from draining out of the filter. While it will not damage the engine not having it, with it you eliminate the annoying valve clatter at start up.
redline oil did a comparison and proved that 0-40 is the way to go the owner uses it on his 911 turbo
it has better cold start properties where most damage starts
Mike
Mike
