Mobil 1 0w-40?
I assumed I would want to go with an oil viscosity of about 15w-50 for my '86 944 Turbo,
Mobil 1's website suggests 0w-40 for my car which seems awfully thin on the cold side.
What do you guys think of this oil viscosity? What is the best for a car that experiences temps between 40-100 degrees?
Thanks for any suggestions.
Here is the Mobil 1 site suggestion:
![Name: Mobil 1 0w-40 oil.JPG
Size: 38.6 KB](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/750581d1375830287-mobil-1-0w-40-mobil-1-0w-40-oil.jpg)
Also, is the Purolator L30165 Classic Oil Filter a good one to buy?
5.49 over amazon but a couple places online said it was one of the best.
Any opinions?
Any opinions?
I agree - I think the 0w-40 is a little thin. I run that in my 996, because Porsche specifically recommends it - I believe because of the variocam actuators. I believe the 944 owner's manual recommends 10w-40. I however, have been very happy with 15w-50 for many years.
I would recommend you get the actual OEM filters. They're about $7 from Pelican - the number is OC-142
I think 0w-40 would be really thin for these engines. Back in the late 70's they didn't have 0 weight oil. It was all at least 10 weight. I would stick to 10w-40 or 20w-50 at a minimum. I run 10w-40 in the winter without issues.
0w-40 would work maybe in a brand new rebuilt 944 engine that has really close tolerances. But with some miles on them, it is better to stick to the thicker stuff.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
exactly. I ran it for 3 winters with very good results before switching to M1 0w50 in my 968.
still, it is probably a bit thin even for a newish 968 engine.
Don't listen to what they or even Porsche US recommend. They have no care for your car whatsoever. Listen to the people that own the cars. There's no problem with consulting your owner's manual either.
What specs are they that suggest a 50w oil is thinner than a 40w?? Especially a synthetic? Reverse that logic 180 degrees and I'd say you're right.
Also I am assuming synthetic no matter what route I go.
If I am not using the car on the track then wouldn't an oil like the SynPower® Full Synthetic Motor Oil 20w-50 be best?
I saw on one warning that racing oils do not contain as many detergents as regular oils, any harm in this?
Hopefully all of this information can help other new owners get their heads on straight and their engines running with the best possible oil!
